2 average scopes on 1 average mount?
6 replies138 views
Tareq Abdulla avatar
Hey all,
Does anyone here placed two scopes of medium weight on a mount that is not rated for very heavy capacity?
For example 2 scopes by each is almost up to 10KG [with accessories] on a mount that is rated for about 20-25KG only
astropical avatar
Hello Tareq,
Only when imaging on the Moon  8)
If you like your Skywatcher AZ-EQ6 GT Mount, then I would vouch against a 20kg payload. Mount manufacturers usually specify a maximum payload which should be taken with a grain of salt. You will definitely experience inferior tracking and guiding accuracy.
I once overloaded my Orion Atlas EQ-G which is about the caliber of your mount. I was painful to hear the gear worms crying.
All the very best,
Robert
sky-watcher (johny) avatar
Hi Tarek,
I  have a Heq5 pro and I used it for years with 2 scopes, the total payload was up to 20 kg.
The recommended payload for the Heq5 is 12 kg
https://www.astrobin.com/s2vz81/?nc=userSince about 2 years I have a 10" newt on the mount the payload is still about 20 kg
https://www.astrobin.com/255037/J/?image_list_page=10&nc=
I could and can do 20 minutes exposures.
I use the Lacerta Mgen2 autoguider with finderscope.
Since  about 4 years works reliable, with a payload of about 20 kg.
This is my experience, but I would not recommend for other people
cs johny
Hello Tareq,Only when imaging on the Moon  8)
All the very best,
Robert
I see, it is difficult to find two cheap telescopes then to keep the mount within limits without pushing it too much, and i keep seeing some people using something like 12" F/5 Newtonian on EQ6 which is on the limit or the edge of the mount capability and they said it was fine, how? And i was thinking about two small scopes not big, but even with two small if i add cameras and filter wheel they will be a bit heavy.
Hi Tarek,I  have a Heq5 pro and I used it for years with 2 scopes, the total payload was up to 20 kg.
cs johny
Well, i wasn't looking for that much, i mean i have 6" F/4 Newtonian which is nearly 5KG, if i buy another same scope that will be 10KG total, and if i add accessories for both say both can reach nearly 15-18KG, then with something else like guide scope i have small lightweight one that will put me at around 20KG, is that possible?
Also if i go with smaller scopes like refractors, i still don't want to buy expensive refractor more than $500 or 400euro for one so both are nearly $1000 or more, i can buy two up to $800 or even $1000 only but no more, so i don't know.
Also my mount is AZ-EQ6, the top quality model of EQ6 mounts, they send the mount with extra saddle, i have that extra saddle which means it can go with two scopes, but i have to know what is the limits of those two scopes and which two not expensive.
If you think this doesn't works for you, the answer is very simple,   don't do it. 😊
I just don't know, it may work nicely or it may not work, so i don't have the answer, why did i ask then.
Counter weights and balance question
Hello community, once again, your help is needed. This time, I am looking for your opinion about counter weights. With my latest purchase of the TS 70mm Flatfield APO I do own a scope with a really great optical performance. My EQ6R Pro handles the s...
Counterweights help balance multiple scopes on mounts with payload limits.
Sep 15, 2021
Using two telescopes on the same mount: Piggy-back imaging
For long, I have been using a small Takahashi scope (FS-60C) as a luxury guide scope for a larger 100mm refractor. The small Tak was mounted on top of the refractor and has served its purpose very well, providing pinpoint stars to the guide camera. R...
Directly addresses mounting two telescopes on same mount setup.
Oct 22, 2021
