Searching for Orion Nebula with a 70mm scope
2 replies305 views
Alien_Enthusiast avatar
Over the past couple of days I've been trying to find the M42 Orion Nebula. However, all my attempts were unsuccessful. I see the Orion's sword with a naked eye, point my telescope to it, and simply end up seeing a bunch of random stars but not the nebula itself. This could be because I'm either not looking in the right direction, or my telescope is not powerful enough. Keep in mind that this is not my first deep sky object, previously I've successfully captured the M45 Pleiades star cluster, and I had no trouble finding it. That could also be due to the fact that M45 contains bright, tightly packed stars, while M42 is a Nebula. I'll attach an image of the stars that I keep seeing every time I point my scope towards the Orion's Nebula. I tried plate solving it, tho all the attempts were unsuccessful. At this point my only hope is someone experienced enough to locate the exact patch of sky within the provided picture. Any advice is appreciated!
Josh McCollum avatar
That's the Orion nebula alright!  M42 (orion itself) is those three tightly packed stars.  The "sword" are those two stars to the right of the image.  You can see the faint nebulous glow of Orion if you look closely.
Oscar avatar
I live in bortle 6 and I saw the brightest areas of the C shaped nebulosity with my 50mm binos. You just got to stare for a little bit, and it's even better if you can find a way to steady the binos, because even with 10x, my hand shakes like crazy.
EDIT: I used averted vision mostly. If is stare directly at it, only the very center is visible as a very pale white glow.
But astronomy doesn't interest me very much at the moment, ya know why? Because a hurricane is coming directly to SoCal, and I live near the coast over there. Hopefully the wind speeds will be much less than 70mph as some forecasts say.
