Arny avatar
My last series of flats all have weird quarter circle streaks across - but only for Ha and Sii, but not for Oiii.
Filters are Zwo 2" Ha, Sii and Oiii filters
in 7x2" ZWO filter wheel
on Asi2600mm pro cooled camera
on Founder Optics Apo86
First I though it was on the camera or lens, but Oiii does not show.
Second I changed the T-Shirt I use to diffuse sky light for the flats, as it is not homgenous. But effect remains despite very homogenous fotographic silk.
Third I cannot see any dirt or spots on the filters, nor does it change with camera rotation.
I get artifacts in individual flats as well as stacked masterflats.
Any idea what I might be facing here?
Arny
Sii sub
Sii masterflat
Ha subframe
Ha master flat:
Oiii subframe
Oiii masterflat
Dave Rust avatar
Could these be cleaning streaks on the camera's protective glass cover? Also, streaks on the back surface of a Field Flattener can cause similar artifacts. I suspect it's not surprising that they'd show up at some wavelengths and not others.
Brian Puhl avatar
Have you tried actually stacking your data with those flats?    Its common for some NB flats to look strange.   Don't count them out unless it actually shows up in the final stack.
Arny avatar
Brian Puhl:
final stacked images look ok and do not replicate the effect, which adds to the weirdness as the stretching of the flats is the same as the of the stacked images …
Arny avatar
Dave Rust:
Hi Dave,
Agree, I will have to disassemble the image train to find out …
Arny
Brian Puhl avatar
Arny:
Brian Puhl:
Take it from someone who just was just helping another for the past week about it.  He has a very similar issue to you.   His pattern was a diamond tho.  My flats look wierd as well, but they never had a pattern like his, so I assumed something might be wrong.    He chased it for weeks, tearing down his entire imaging train.... it ended up being nothing.   The final stack was fine.
If the final stacked image looks fine, then don't chase it.   It's doing exactly what it's supposed to do.
O3 filter calibration issue
Since I had my QSI690wsg-8, all my filters got calibrated very well except the O3 filter, It left uneven illumination on my images with weird artifacts making image processing challenging with some targets. I don't have this issue when I swap the...
Selective filter problems with O3 and other narrowband filters causing artifacts.
Jan 16, 2022
Artifacts of imaging: an important lesson from the Hubble Telescope Archives
Hello all, I wanted to address the issue of ARTIFACTS of imaging here, because I think it is important to consider this in Astrophotography. The description below, was derived from one of my posts, in which, by processing an image from the Hubble Arc...
Addresses mysterious artifacts appearing in astrophotography image processing.
Dec 22, 2021
PixInsight -- separate flats for different filters?
I tried PixInsight for the first time tonight for stacking and was quite impressed. I was using the WeightedBatchProcessing script and really liked the way that it automatically split all my subs by filter and created master stacked images by filter ...
Relevant — discusses filter-specific flat frame issues and problems.
Nov 11, 2021
