Large halo around target after stacking
2 replies235 views
Chase Davidson avatar
Hi everyone, I’ve taken ~5 hours of 5 min Sii subs of the Pac-Man Nebula with my 130mm refractor and asi2600mm. I ran subform selector in pixinsight with the parameter that eccentricity <7 to filter out the initial bad frames and then blinked the remaining frames that looked bright. I live in south Texas so many of my subs start to show signs of dew formation on the lens sometime towards the end of the night.  I usually throw those out immediately.
This time around I ended with just over 3 hours of usable data that all looked good in blink. After stacking with my other Oiii and Ha data in WBPP, my Sii master frame looks like it has a terrible halo around the Nebula. Am I missing some extremely bad dew sub frames? Would dynamic background extraction remove this (probably night, right?) Is there anything else that could be causing the halo? See attached picture of my master light Sii shot after initial stretch.
any help would be greatly appreciated!
-Chase
Brian Puhl avatar
Kinda looks like dew to me.    Small chance it could be flats.  Rule that out by simply stacking without.
Background extraction utilizing division method might work, but I'd use that as an absolute last resort.
Went back and looked at my subs and couldn’t see any dew in my lights but just so happen to check out my flats for that day and they are horribly dewed up! Good call, thank you!
-Chase
Extreme integration times and stacking
Recently, I've completed capture on a single frame with more than 400 hours of acquisition time–my longest ever, obtained only after suffering the pain equivalent to delivering a breach birth. It's a project I started in 2024, when I go...
Relevant for understanding integration strategies with substantial data collection.
Apr 20, 2025
FWHM vs Eccentricity - How to filter the good frame in Subframe Selector in PI
I had a really good night of imaging the Statue of Liberty but the following night was not as good. I use PI's Subframe Selector with the below settings to filter out the good from the bad. As the Subframe Selector calculates an average over the ...
Directly addresses Subframe Selector filtering parameters and frame quality assessment.
Feb 4, 2025
An observation about culling
I was watching the subs come in for the Crescent Nebula the other night and after awhile I noticed that when there would be a hiccup in the guiding (it was a windy night) the stars in the image would trail but the details in the nebula seemed unchang...
Discusses frame culling methodology, complementary to author's quality control approach.
Jul 23, 2025
Is this dew?
So, I have a really silly question; I ask because I am trying to not buy something I might not need. Over a few nights I've discovered my pictures end up being cloudy after a few hours. Being in Seattle, I just figured clouds moved in. Though I r...
Stacking issues could relate to dew affecting image quality.
Aug 19, 2021
Help. Pollution or something else ?
Hello I just started taking photos in December so extremely new to me. Though I’ve came across a little nag. im using a skywatcher 200p on an eq5 pro. I use an asiair and a asi120mm mini as a guidescope. My main camera is an unmodded canon 700d. basi...
Large halo around target after stacking may indicate similar processing problems.
Jan 24, 2022
