Bradley Watson:
If I have shorter subs, the SNR is lower right, so with more subs I am introducing more noise. e.g. if I shoot a 5 min sub vs 5 1min subs, is the noise more or less? I know there are other variables but I feel like with my Mak with longer exposures I am introducing less noise but increasing signal. Challenge then becomes guiding and it’s painful throwing away 5min subs! Right now I think adding more data with an F12 scope can only be a benefit.
SNR=So/N=So / SQRT (So+Ss+Sd+R2)
Here is the formula for SNR and here you can see the factors affecting the ratio (So is Signal object, Ss for sky, Sd dark and R is read noise).
An important aspect is this shot noise cannot be subtracted since it is random, this is not the dark current subtracted when doing darks. As you can see what matters is not only the absolute value of each contributor to noise, but their
relative value. So if you are shooting under dark skies you're really going to be concerned by read noise. If you are shooting under LP skies like me (you are also in the same scenario I see), read noise is going to be much smaller than sky noise due to LP. In an ideal scenario shooting one 10 min sub vs 10 subs of 1 min would be equivalent. If you shoot a 10 min RGB sub under Bortle 7 skies (even with the LP filter) your object is going to be drowned in the sky signal. You cannot just increase the sub duration as you please since the sky (really) is the limit. The other aspect is the
read noise with multiple subs. So yes, using 1 min subs will add more read noise. The question is not if the read noise increases, but what is the best
ratio[b] [/b]compared to the sky noise.
As a practical example I used 30s and 15s L subs for my M13 photo. Pretty low gain 0.5 e-/ADU (under unity which is 1 e-/ADU). So I increased the read noise considerably. My signal for this bright object is high (So is high) and my Ss dominates (Bortle 7/ 8 ). Well, the background for this image was one the cleanest I've ever had, I used 192 subs which decreased the noise 14 times. But this scenario does not apply in your case, since your object, a planetary nebula is not as bright as a globular cluster.
By using narrowband filters, you will increase the SNR since you will decrease the Ss (the LP from the sky background is considerably reduced when you shoot through a 3nm passage vs 300 nm passage for L.
The duration of your sub length should be dictated by the ratio object magnitude vs sky magnitude under LP. Second aspect is your
F ratio. Shooting with a Mak is not adapted to deep sky, it collects few photons. Each F stop will double the quantity you get on the camera chip. So go with the refractor at F7 or use a reducer to get it at F5.6 (0.8x reducer). Much better than the Mak (but less aperture and resolution of course). One aspect that people usually misunderstand is that by using a reducer you are not going to shoot
the same object faster. The reducer will increase your field of view and more light will hit the chip, but from a larger field. Your object will generate just as much photons on the chip as before (it became smaller in the fov which compensates the increase in speed of your system).
I hope I was clear enough, this topic touches a lot of aspects so it is easy to be convoluted in what you're trying to express.
Bogdan
