2600m pro - Backfocus to Skywatcher Esprit 100?
5 replies273 views
Daniel Renner avatar
Today I got my 2600mm pro with a 36mm filterwheel. Im not really sure if I have installed it correctly to fit my telescope...
I removed the tiltplate and screwed the camera directly to the filterwheel and then used the 16.5mm spacer to screw it on my fielflattner... but this doesnt get me 56mm backfocus? Do I need to install the tiltplate ? or have I missed something?
This is what I did, is it wrong?
or is this the correct way?
[ASI2600 Guide] 4 Connection methods to get 55mm back focus length – ZWO ASI (astronomy-imaging-camera.com)
Marc avatar
you just need do use the 22.5mm extender instead of the 16.5mm you use at the moment and your good. if you only have the 16.5mm extender you have to use the tiltplate. the additional 1mm backfocus (56 instead of 55mm I guess for filter compensation) you can achieve with a 1mm spacer ring between one of the threads.
Marc:
I tried to use the 22.5mm spacer but that didnt fit my fieldflattner...
Marc avatar
make sure there is no adapter ring on the 22.5mm or the 16.5mm because they should be both M42M-M48F and there is an adapter ring included.
Tom Boyd avatar
Daniel Renner:
Second way. Put the tilt plate back on the camera. Filter wheel attaches to the tilt plate directly via four screws through the back of the filter wheel and into the tilt plate.
Patrick Graham avatar
The user manual for the Esprit 100ED calls for a 63mm back focus distance.  Thru a combination of spacers and adaptors, you should be able to achieve this.  I have a Esprit 150 ED that requires 96mm of back focus.   It was a puzzle fitting the right adaptors and spacers to get that, but finally did it.
Patrick
Skywatcher coma corrector and zwo filter wheel back focus distance
I'm trying to get the back focus sorted on coma corrector. My equipment is a Skywatcher 200PDS with the 2" coma corrector from Skywatcher. I'm using a ZWO filter wheel, ZWO filters and a ZWO ASI1600MM camera. I currently have it set up w...
Different telescope model but similar back-focus and filter wheel setup questions.
Nov 24, 2021
Back Focus Frustration
I am trying to stitch over my ASI533MC Pro with ASI Filter Drawer and the required 16.5mm spacer for that party of the image train to reach a back focus of 55mm. I know that is solid because I have used it for years on my refractors. I am finally try...
Back Focus Frustration — Similar ASI camera, filter drawer, spacer, and back focus alignment issues.
Mar 24, 2025
Proper backfocus with x0.63 reducer
I’ve been struggling quite a bit with dialing in the correct backfocus for the f/6.3 setup using the reducer, aiming to get as close as possible to the theoretical focal length — 1280.16 mm (2032 mm × 0.63). The originally proposed distance of 105 mm...
Proper backfocus with x0.63 reducer — Directly addresses achieving correct back focus distance with optical components.
Apr 22, 2025
