"Glow" randomly appearing in RisingCam IMX571 images
13 replies702 views
James Tickner avatar
Apologies if this question has been asked (and answered) before, but I haven't found it mentioned elsewhere.I recently purchased a RisingCam (rebranded ToupCam) camera: Sony IMX571 26MP APS-C sensor, TE, OSC. I ired it up for the first time last night. It was immediately recognised by NINA and cooled down quickly to a set point of -20C. So far so good!The trouble started when I tried to collect dark frames. About 70% of the dark frames look absolutely fine, with a mean pixel value just above the programmed offset level and a small standard deviation. However, about 30% of the frames show a gross 'glow' - it doesn't really look like amp-glow, but it shows large scale structure. The appearance, structure and intensity of the glow is consistent between bad frames. However, bad frames seem to appear at random eg good, good, bad, bad, good, bad, good, good, good etc. The settings I used where minimum gain value (100), offset 250, sensor temp -20C, high gain off, ultra-low noise on, 60 s integration. I tried changing the high/low gain, sensor temperature setting and ultra-low noise settings but it made no difference. I then tried collecting some light frames and observed the same effect: good and bad frames are randomly intermixed, with the bad frames showing the same sort of superposed 'glow' as the bad dark frames. Again, about 25-30% of frame were bad with the remainder fine. The attached image illustrates the problem, showing typical 'good' and 'bad' dark frames (top) stretched to cover the ADC range 0-1000, and 'good' and 'bad' light frames (bottom) stretched to cover the ADC range 0-3000.I would appreciate if anyone has any insights or suggestions for further tests!
Well Written Helpful Engaging
wittinobi avatar
try with lower USB-Speed in NINA (try USB Speed 2 or 1 instead of 3).
Thanks for the suggestion!
Actually, I contacted the manufacturer who supplied an updated driver for NINA. Touch wood, but that seems to have solved the problem.
Well Written Concise
OnlyCloudFish avatar
Yes update to new driver solves the problem
Phil Wright avatar
James Tickner:
I don't suppose you know if they're available online do you? The ones on the website are still saying from 2021?
Here's the link to a document describing the installation process. The document itself contains further links to download the SDK.
https://drive.google.com/file/d/1ul1VOr5NJiu7exJs-k6h4mazU9_Yw0oQ/view?usp=drivesdk
verticalmagic avatar
Sometimes I have this issue (I use the color version), I suspect it is due to some bad USB cable connection, now I always unplug/replug the cable before a session to make sure the connection is "fresh" and if I get the problem mid-session I wiggle a little bit the cables to create a better contact. I think the problem was already reported on other forums but I cannot find it.
Thierry Boufflet avatar
Hi James, did you solve your problem with the new drivers ? otherwise I would suggest to look at you power supply our the quality of you AC.
Good luck
PS: I'm really happy with my 2 RisingCam IMX571 Color and Mono
Marc avatar
I have the same issue with my touptek Omegon clone but I just live with it. had contact with Omegon and so on, no solution found so far. its like 1 or 2 frames a night that show this issue. I have it more on my Mele quieter 3 miniPC than on my regular Dell Laptop. I use USB speed 2 in Nina under the camera settings to mitigate the issue (most bad frames seem to appear with USB 0 for me, Omegon has USB 0-2, not 1-3).
Concise
Good luck
Yes, the new driver completely eliminated the problem (so far at least).
And although I've only had it a few days, I'm also happy with my RisingCam IMX571 so far. I've had a smaller uncooled mono RisingCam device for about a year now and that has also performed flawlessly. Their service is also really good - Eddie usually responds within mintues (even at the weekend) and is very knowledgeable.
Phil Wright:
James Tickner:
I have heard that they are building a new website exclusively for astro product.
I got the same suspicion before but then updated to driver version 20230723 and now it is totally fine. sometimes it might fail, but 99% of the time its fine.
Marc:
I think there might be a new driver update for Touptek on NINA soon to solve these problems. Omegon's drive should be updated together. But I think Omegon should have the lastest driver that solves the problem.
James Tickner:
Good luck
:-D Yes Eddie is really efficient, I also noticed that he called me on week end in the past. I was some of the first user of IMX571, I was a little bit worried at the beginning because there was not a lot of feedback from other users. I have no regrets for sure. I'm happy for you that you problem has been solved. Nice sky James (where are you? I'm in Provence in south of France)
WBPP Dark Calibration
Ran into something odd today and could use some help figuring it out. I’ve been using PixInsight and the WBPP script for a while now without issues, but this time my darks seem to be overcorrecting my lights. After integration, there’s a noticeable d...
WBPP dark calibration issues relevant to dark frame collection problems.
Apr 26, 2025
Omegon veTEC 571 C Color camera question
Hi, found some amazing images captured using Omegon veTEC 571 C Color camera. It use same sensor as ZWO ASI2600-MC-PRO want to ask if anyone used it or is Omegon camera company trustworthy as zwo which has great customer support? From where I can buy...
RisingCam uses same IMX571 sensor; directly relevant to camera comparison.
Oct 31, 2021
Touptek 585 c Offset doesnt work?
Hey guys. I am a proud new owner of the Touptek atr585c camera. However, I was testing it tonight and when using the HDR mode with few different settings for Gain and Offset, it seems to be too noisy. Also the Offset doesn't work, whatever the va...
Touptek camera troubleshooting directly applicable to RisingCam/ToupCam rebranded equipment.
Dec 18, 2024
Review: ToupTek 36mm LRGB and SHO Filters.
Thought I'd share my thoughts about the ToupTek Astro filters I've been using. Brilliant budget friendly filters. ToupTek Astro 36mm LRGB + SHO Filter Review. Introduction.We all know how expensive astronomy can be. Further to that, we all kn...
ToupTek equipment review useful for understanding rebranded camera manufacturer products.
Mar 27, 2025
