Long term AP setup suggestions required
3 replies177 views
Abhijit Juvekar avatar
I like to experiment with different OTAs for Astrophotography.
Initially, I had Sky-watcher 6 inch & 10 inch Dobsonian through which I have done some Planetary & Lunar surface imaging.
Later I sold it away for getting the DSO imaging setup.
I currently have the following setup.
iOptron iEQ45-PRO mount
Sky-watcher 130 PDS (Newtonian)
Sharpstar 60ED APO (Refractor)
GSO 6 RC (Ritchey-Chretien)
I have seen many people with backyard observatories using either large Newtonian 10/12 inch or 5 inch Refractor as their primary telescope.
Want to know which telescope should I opt for the long term DSO imaging.
Note that my sky is limited because of high rise buildings in surroundings so my view of the sky is limited to around 2-3 hours for any target.
Should I consider 8-10 inch F4 fast Newtonian or get a quality Double/Triplet Refractor?
Astromatthi avatar
Hi Abhijit
First question should be like: Which one of my telescopes I like the most? You have a Newt a RC and a Refractor…
For me it was clearly the newton.
Because:
-Temperature stability
-Aperture
-Focal Ratio
-Price
One of the biggest advantages over a refractor was (for me) Temperature stability. I need to focus once per night (per filter) and i am done.
Your apo might have an carbon tube which looks nice, but your lenses are the problem. The focus point changes with or without carbon tube.
I have no idea about the RC because I do not have one smile But I think it should nearly behave the same as the newton. But the big contra for me is the low f- ratio.
Hopefully, I could help a bit with your decision smile
Greetings from switzerland
Supportive
NighttimeskyGuy avatar
Hard to go wrong with an APO refractor. So easy to use. Spend 2 minutes focusing every fourth 5 minute frame and you are probably good even in the worst conditions.  Take it anywhere. No messing with collimation!
Bob
David Redwine avatar
With only a 2 to 3 hour imaging window you need to focus on imaging efficiency .   Imaging efficiency is measured by a parameter called E'tendue which is the actual photographic field of view, image width times height,  in arc seconds squared,  times the collecting area (objective area corrected for obstruction).   Optimizing E'tendue alone will lead you to a wide-field scope with somewhat low resolution so you have to decide what resolution you want, then select the scope and camera you can afford that gives the desired resolution and the best E'tendue.
Or you can just buy a RASA , Hyperstar or Takahashi  Epsilon ($$$) with the largest camera that works with the selected telescope.
Factoring in other parameters may change the answer, but with such a small imaging window imaging efficiency should remain high on the list of factors to consider.
E'tendue= FOV*CO
where FOV is the actual camera FOV and CO is the corrected objective area.
Helpful Insightful
Remote dark sky Astrophotography trip equipment selection ?
Hi, On short notice, I planned to join 2 nights dedicated Astrophotography trip at Bortle 2 sky location. I have Sharpstar 60ED APO refractor (330mm F5.5), Sky-watcher 130PDS (650mm F5), GSO 6 inch RC (1370mm F9) telescopes ZWO ASI 1600MM-Pro camera ...
Author has Sharpstar 60ED APO; dark sky trip planning directly relevant.
Jun 3, 2022
EQ6-R Pro with 10" Newtonian
Hi all, I currently have a 100mm APO refractor on a Sky-Watcher EQ6-R Pro mount. I am considering options for a second OTA of longer focal length. I have found a premium carbon fibre 10" f/5 Newtonian astrograph but I'm not sure how it would...
Author experimenting with different OTAs; post discusses 6" and 10" Dobsonian experience.
Nov 7, 2018
Upgrade advice required
Hello, I am using ZWO ASI 1600 MM-PRO since 2018. Have 3 OTAs : GSO 6 inch F9 RC, Sky-watcher 130PDS Newtonian, Sharpstar 60ED APO doublet Refractor. ZWO 1600 MM-PRO is working absolutely fine, the problem is my local sky is now surrounded by high-ri...
Author owns identical OTAs and camera; upgrade discussion highly applicable.
Oct 5, 2021
Help me pick a new Refractor! ~600mm at ~f/5.6 reduced or native
Hi everybody, I‘m in the market for a new refractor. I want to get deeper into galaxy imaging and my current 80mm f/7 ED Doublet is a little limiting in terms of image scale and resolution, even paired with the 183MC Pro. I really don‘t want to get a...
Author uses multiple refractors; galaxy imaging refractor selection relevant.
Oct 20, 2021
First DSO Camera suggestion required
Hi, I have Sky-watcher 130 PDS & 60 mm APO Refractor telescopes with iOptron ZEQ45 PRO Mount. Have ZWO 290 MC camera which I use for Planetary & lunar surface imaging. Want to move in dedicated DSO imaging. I live in the red-zone light-pollut...
Discusses AP setup experimentation; relevant to author's equipment selection process.
Sep 1, 2018
