Telescope dolly, DIY
22 replies913 views
Daniel Renner avatar
Have anyone here built a telescope dolly like these? (these are not mine)
if so, do you have any plans you can share on how you built it? is it stable enough to image from?
Ed Litoborski avatar
I don't have plans, I just looked at a few on the internet and made my own based on the dimensions of my mount.  I am lucky as I have a small work shop I can fab and weld small project like this.
I added outriggers to aid in stability and leveling and some weight.  The outriggers are setting on concrete pads pored in the dirt.   My outrigger leveling screws have points ground on them and their are pointy divots in the concrete, so I align the 3 screws in the divots and then polar alinement takes less than 5 min.
Its HEAVY but solid as a rock.  No issues with guiding or movement .  Burrr, this picture was taken at 15 deg f last winter.  Moving from my garage to this spot takes me 10 min or less.
PS, if I didn't have the ability to fab my own, and after using it for a year, I would consider buying the "Scope Buggy"  I see advertised in Astronomy mag's.  I think they run about $350.  REALLY speeds up set up things being able to wheel it out level and PA very quickly.  I leave mine on the buggy when parked in the garage.     My truck sits outside lol
Wes Schwarz avatar
Ive thought about bolting casters onto a pallet in my driveway and using that as a platform lol
John Hayes avatar
Every one of the dollies shown here share a potentially fatal flaw.  None of them appear to have a jack screw for lifting to dolly off of the wheels for imaging.  Imaging on a wheeled dolly will almost certainly limit the quality of the results.  Another potential problem is the use of wood, which isn’t mechanically very rigid.  Wood can work for a small light scope but just don’t touch anything while the scope is running.  Remember that at 1”, everything (even metal) is made of rubber!  That means that you should use the most rigid materials possible.
You can see the roll out platform that I built for my 20” scope here:
https://www.astrobin.com/dlko5b/N/
I was concerned that this setup might ring as well, but it turned out to work really well.  The entire rig weighed around 700 lbs but it took two fingers to roll it out and it provided sub-arcsecond stability.  It was also extremely easy to polar align.  I didn’t realized it when I designed it but the arrangement of the jack-screws provided near orthogonal polar alignment capability in altitude and azimuth.  Using a PoleMaster, I could have PA done in about 5 minutes and a 70 point full sky model done 10 minutes later.
Wes Schwarz avatar
John Hayes:
I have some of these machine tool casters https://www.amazon.com/Homhoo-Adjustable-Anti-Vibration-Workbench-Equipment/dp/B0B62J1ZRV/ref=sr_1_3?crid=2KGC0PKXG03NX&keywords=3"+level+casters&qid=1691275728&sprefix=3+level+caster%2Caps%2C181&sr=8-3  which I think will suffice for a rig that weighs maybe 150lbs tops.
John Hayes:
  Mine lifts the wheels off the ground.
Djennings avatar
A little late to the party but here is my so called Dolly.
Monty Chandler avatar
I use these piano mover casters.  Just roll my rigs out of the garage about 50' to my driveway.  Removing the casters and placing the legs in their exact position on the driveway makes polar alignment very easy with the polemaster.  This way I never disassemble my rigs.  Cheers
https://www.uline.com/Product/Detail/H-5245/Dollies/Leg-Dolly-2-Casters?pricode=WB1828&gadtype=pla&id=H-5245&gad_source=1&gclid=CjwKCAiA-bmsBhAGEiwAoaQNmtg_AUukbfA8Qqkl9c-o7Larow9dx-HeZvNNgBWuejVG4H4rizi7phoCggIQAvD_BwE
Djennings avatar
Monty Chandler:
Hey Monty,
Those would work great however, my driveway is all rock, no concrete. Hence the much larger rubber wheels on the wagon, it rolls over the rocks much easier.
Good choice though for those that have concrete to roll on. My old house had a concrete driveway and that would have been great for the casters.
Thanks for sharing,
Clear Skies,
DJ
Roy Hagen avatar
I first made a jack up dolly, but found it to be very sensitive to wind, so I came up with a solution to lift the wheel up and lower the dolly on the ground
Djennings avatar
@Roy Hagen Excellent idea Roy..
Love the ingenuity and making it work as needed.
Good job.
DJ
Roy Hagen avatar
Good job.
DJ
Thanks, DJ👍
It is as far as I can see, a very stable dolly
Jeramie avatar
Great thread!
I've owned one of the old JMI carts and a Scopebuggy. The JMI was pretty good, but the Scopebuggy was not so great for me. Both could be wobbly. The Scopebuggy dumped my C11 twice. I caught it once, and the other I didn't.
My C11 is away for repair at Celestron, and I don't plan to use it again until I can get a good mobile platform for getting it in and out the backdoor.
Love that pier cart @Roy Hagen!
Djennings avatar
Great thread!
Yeah,  both of those would have been too wide for my application and yeah, so sorry to hear about the C11 being dumped, that would be awful to deal with. Hope you get that fixed and back into action soon.
Clear skies,
DJ
Mo avatar
I built this one.  I learned to weld to make it.   All of the parts are listed in the post.  It has been a real back saver.  You can make it to fit you own dimensions.
https://astrob.in/a98azj/B/
Roy Hagen avatar
Great thread!
@JayRuhMe  Thanks, my friend. I do not claim any copyrights on this one🤩, I just have to make something to fasten the pier to the dolly.
Linwood Ferguson avatar
I went a different way.  The problem I have is to come out the back door I need to traverse both a step, and two doors.  Come out the front (say the garage) where there is room and I have to make my way over quite rough ground with a dolly.  So....
I take the OTA and counterweights off (the latter more because I worry about their bouncing around damaging the mount than weight).  I move the mount and tripod with a handtruck customized to be wide enough to reach two legs, and narrow enough to go through the doors, with wheelbarrow tires that are really large to handle rough ground:
The black pillows cushion it when I tip it back, the strap (visble going between the RA axis supports) is just a big piece of velcro to help tip everything back.  Notice the spikes.
When in place, I have a second handtrick with egg crates.  The top one holds all the counterweights (I put a wooden bottom in to re-inforce since it may carry over 100 pounds for some OTA's), the middle has two power supplies, the bottom is empty and just to save me bending over.  This also has big tires but those are stock tires, not modified.
I carry the OTA's out by hand, I do not trust them bouncing around.  Finally (next image)....
The spikes on the tripod go into pavers that remain in the ground, where I drilled holes that are NOT large enough for them to go all the way down.  This means they are held by the circumference of the spike not the tip, and self center in the paver.  By doing this (and not moving the mounts alt/az) I end up polar aligned withing about 2-5 arc minutes provided it is the same OTA as last time (if I change OTA just the weight difference plus mounting hardware difference may put me half a degree or so off).
Landing this close to polar aligned saves a lot of time, since I am just tweaking it not starting degrees off and potentially having to actually rotate the tripod (though the AP mount has a really large Az range so that's rare).
Carrying out a C11 to place on it is my worst part, not because it is the heaviest (my SVX152T is about the same), but because it is really awkward to hold and place in the saddle.  But all the rest -- the mount, counterweights, tripods, etc. are just a matter of rolling and putting in place.  It's not as nice perhaps as a dolly that I could roll the whole way, but I image in SW Florida, so half the year that grass is a muddy mess, I'm not sure how well a fully assembled (and thus VERY heavy) setup would roll on any reasonable sized tires.  I'd almost certainly need a powered one to keep from getting stuck in the mud or wearing myself out.
Think "Monster Truck" dolly.  Not exactly my idea of imaging.
But this works.  I can be set up or torn down in 20 minutes easily (+/- taking flats).
Linwood
Jeramie avatar
This thread inspired me to go and solve for some problems that myself and others have had when it comes to moving large telescopes around. Below is my beta/POC version of my first Mobile Pier Cart. I plan to start my own little business and sell this and a few other models I'm still designing.
Details are as follows:
  • 6-inch, hollow, square pier. This allows you the option to fill with sand for vibration dampening.
  • 1/4-inch plate on all parts
  • Pneumatic casters on sealed hubs
  • 25-inches wide, 40-inches long. Fits easily through standard interior home doors.
The deck/slab plate can be mounted to a wooden deck or concrete patio slab. The cart rolls over the deck plate and screws down into the deck plate to lock the cart in place. This will help in maintaining polar alignment and prevent any accidents from happening where the scope may tip over. I am planning 3 models to support scopes of various sizes.
The problems that this cart solves for me are:
  • Stability in imaging
  • Ease of setup as it never has to be torn down.
  • Rolls very smoothly across any surface.
  • Allows me the convenience of having a pier and being able to move my equipment indoors nightly.
First night imaging with a C11/Hyperstar on a AM5 I was averaging .5 RMS in light winds. A second night with 20+ MPH gusts put me at .8 average. I'm happy so far and have testing this week at 2800mm focal length. We'll see how it does there.
Helpful Respectful Engaging
Nikul Suthar avatar
@Djennings  I like your idea... A few questions though... Do not you get movement from the cart when there a windy breeze is going through? Also is the black color leg the one to give stability to your setup? Can you please provide some photos to know more about it?
Michael von Berner-Purgstall avatar
Good Morning!
As already said here - the wheels on the ground are a weak point. I'm using a professional dolly, german made, for my Sky-Watcher ESPRIT 150ED and AZ-EQ6 mount head, see here:
Euro EMC Astro
You do have 2 rubber wheels but those are OFF the ground during recording and it works great.
best regards
Concise
Rick Krejci avatar
I just go from garage to driveway and have a JMI Medium Heavy Duty Wheeley bar for my setup which works very smoothly for moving the setup around.    But neither the wheels nor the screw risers were sufficiently stable for imaging.    I removed the screw risers and cut up some 6x6 wood blocks and a small lifting tool to raise each leg up onto the blocks ( https://www.amazon.com/dp/B0CJFW9FY5?ref=ppx_yo2ov_dt_b_fed_asin_title) .    Takes me a few minutes and allows me to fine-tune the leveling with shims and is absolutely rock solid.
Willem Jan Drijfhout avatar
It's not DIY (although you have to assemble them yourself), but I've found the EuroEMC rolling pier to be an excellent solution. Two big air-pressured wheels rolling around outdoors gives high manoeuvrability and makes it easy to go over bumps. Three small swivelling wheels for indoors allow you to wiggle it through even a somewhat narrow doorpost.
The whole system rests on three spikes, which make it a very solid base. I've used up to a CDK14 on this system with good success. For details on how I've implemented this pier in my duo-backyard setup, feel free to checkout this blog that I've written about it.
