Power cable for astro-cameras
7 replies414 views
Daniele Borsari avatar
I bought my first dedicated astronomy camera (ZWO ASI533MC Pro) one month ago and I did two imaging sessions since then.
I don't use the original ZWO power supply, but I use one from Amazon, which has a cable with an angled connector.
I find that the angled connector works well when the camera is parallel to the ground, but this never happens while doing astrophotography and when I point to the Zenith the cable is not going in a straight way to the power supply.
I have this question: what kind of connector between angled and straight do you use/prefer with your astro-camera?
Daniele
Benny Colyn avatar
Angled is nice (more compact), but combine it with a form of strain relief (zip ties, velcro, 3d print) so tension on the cable doesn't pull on the connector.
Davy Viaene avatar
Maybe not the answer that you are looking for but use cables in silicone, plastic cables become hard with low temperatures and pull on your setup what gives more guiding errors.
tjm8874 avatar
Cables should go to center of telescope, then loosely tied to mount (where not moving), then outside power supply and PC.
no tension anytime
https://stargazerslounge.com/topic/117470-telescope-cable-management/
@tjm8874 I saw your post on Star grazers lounge, did you use angled or straight cables?
tjm8874 avatar
Daniele Borsari:
generally...
Camera side : Angled is better for short cable loop = less wind blow, less chance for hitting something.
Power Supply or PC/ASIAir side : I don't care angled or straight
Bill McLaughlin avatar
Straight and I make my own because the ones you can buy are often crap and I have had them come apart. Plugs from Mouser, Silicon Wire that is not stiff, and some good adhesive heat shrink. They will be the right length for your setup, last forever, and have decent solder/crimp joints.
Bill Powers avatar
I generally use straight connectors with heavy duty size 14 AWG wires.
High Current 2.1 dc power cables
I am looking to run virtually my whole set up through a Pegasus Power box using a Albrect SW102 power supply. The power supply has banana plug outs so I need a cable with banana plugs on one end and a 2.1 dc connector on the other… AND it needs...
Author seeking power cable solutions for astronomy camera setup.
Dec 13, 2024
What has happened here
So my first crack using a dedicated astro camera and I get this as a master dark (in APP). What the heck? Mike
First-time dedicated astro camera user; relevant for setup and initial configuration help.
Dec 20, 2021
Power issues!
Hi all, I'm having some issues with powering my astro gear. Whenever current draw is high (like when cooling camera), my input voltage gradually drops until it is near 10.5V. Obviously, this is not ideal for the equipment, but simply purchasing a...
Power delivery issues relevant to camera operation and setup.
Apr 8, 2025
