RCC Camera Tilt Help
3 replies304 views
DavesView avatar
Help determining what I have in the way of tilt.
CameraTilt_ASTAP_FLT91_ASI294MCPro
DavesView avatar
I must have zoomed the pic in ASTAP and hid the results of the tool. Different sub from the same set, showing the results. I started looking at this because I thought I noticed deformity in the stars to the left side of the picture. This is a 300s sub. Should I use shorter durations and is mild tilt something to worry with?
JohnHen avatar
Did you try  to analyse with NINA Hocus Focus plugin to verify the ASTAP measurement? (if not, you should ...)
I recommend this thread on CN:
https://www.cloudynights.com/topic/809050-tilt-discussion-astap/
It has all you need to know about tilt.
CS, John
P.S.: Yes, 300s is far too long. Try 30s or less with L filter.
DavesView avatar
CS, John
Good read! I'll be ordering an adjuster and fine tuning mine. With NINA, I don't see a way to load a file other than to load an Auto Focus session. Anyway, I have a much better understanding of tilt thanks to the thread. Appreciate the guidance.
Supportive
Tilt
I have sensor tilt and trying to get rid of it. I am really unsure of how to physically adjust my camera (ASI2600MC) to fix it. The good news I think is tilt is right where the adjuster bolt is. I have taken 5 images of M44 and shared a picture of wh...
Directly addresses sensor tilt adjustment methods for similar ASI camera models.
Mar 16, 2025
Correct orientation of QHY600PH-M
In preparation for installing a Wanderer Astro ETA (Electronic Tilt Adjuster), I want to make sure that I have my camera oriented correctly so that the ETA software will adjust tilt correctly (and not upside down). What is the correct orientation of ...
Discusses camera orientation and electronic tilt adjustment preparation procedures.
May 11, 2025
Custom M54 tilt adapter to suit QHY CFW3M-SR & OAG-M system, fits within 55mm BF - Design Files Included!
Hello all. I have a QHY 294M-Pro, CFW3M-SR, and OAG-M fitted to my Vixen R200SS newt. I have been battling tilt with my 294M ever since I bought it, and have been stumped by the lack of suitable tilt adjusters available on the market (especially in M...
Describes tilt problems with QHY 294M-Pro and custom tilt adapter solutions.
Jan 1, 2025
