[RCC] Advice on Eagle and Swan nebulae mosaic
9 replies357 views
Pedro A. Sampaio avatar
Hi everyone.
I've recently published a 2-panel mosaic of the Eagle and Swan nebula, capture with my Esprit 100 and ASI 2600MC OSC. I think that for the most part, I like the result. The detail is nice, and 8h plus in each panel meant I could push the stretch without raising too much of the noise level. BXT, NXT and SXT suite also meant I could work well on the details and keep the intensive star field in check.
I think, however, that the image lacks a certain "oomph", that is hard to describe. But the image still doens't have that "awesomeness" that I was expecting it to have.
I think that one of the reasons is that is that it's too monotone - too much red and not a lot of other colors, specially blue/teal. I know this is a common issue in regular LRGB/OSC images, as Ha pretty much dominante over OIII and other signals. But I wanted some advice on how to stretch the image and get those nice Bluish/purple OIII+Ha signals specially in the center of the nebulae. I know it can be done, as I've seen other RGB images with this profile.
Also, I've recently been having issues with Pixinsight after color calibrating, SCNR and stretching (with GHS), I usually get a blue tint in the background which I can't really pinpoint where is coming from.
From Swan to Eagle, a mosaic
Helpful Respectful Engaging
Joe Linington avatar
I have tried a few times doing an Ha Oiii separation at stacking. I know how to do this with APP and Siril but unfortunately not PI. Then you can perform a linear match in PI before combining the channels and process it more like a NB image. I actually have an older OSC image I was going to treat to this process this weekend so I'll post my results and process (if it's any good).
I have also had some tints when using GHS. There was an excellent youtube video put out by Paulyman Astro on colour balancing while using GHS stretch. Other than that, I have just tweaked the curves a bit to neutralize out any blue or red tint in the background.
Joe Linington:
Thanks for the tips! I've done channel separation when using a dual NB filter, in order to get an aproximate HOO image. I've never done it for RGB images, though I supose I could try to stretch the blue channel a little more than the other channels in order to increase the blue? It may not look natural in the end, after all. Guess I could try.
As for the videos on GHS, thanks again! Those were very informative. In fact, I noticed I've been using the Symmetry Point feature the wrong way, and that may explain why my RGB channels get so separated after the stretch.
Respectful Supportive
Álvaro Méndez avatar
Did you use a dual narrowband filter? I only get the blues when using these (L-enhance or Ultimate). If I shoot nebulae in broadband, it is like the other wavelengths interfere with those rich colours. Pinks become brownish and blues become grey.
One thing you could try is perform a slight blue S-curve over the nebulae, that should bring the existing blues up a bit. When doing this always try to keep the background the same comparing with the original so you do not bias it.
Oscar H. avatar
Álvaro Méndez:
No, imaged with a clear filter, so it's broadband. Interesting that when I used the IDAS NBZ dual NB filter, I get only red... So I think it really depends on the target.
@Pedro A. Sampaio
Have you seen this video? https://www.youtube.com/watch?v=_6in5Kvo95s
I think you need to see this also: https://www.youtube.com/watch?v=SQmFFkF6XhM
Thanks! I'm watching right now! It seems very useful - Color masking is something I've shied away until now in my processing. Those solutions seem simple enough. And applying that to curves may help to bring those colors back.
Thanks to all the tips and several YT videos later, I managed to improve in the colors! I am now much more satisfied with the result!
Oscar H. avatar
Yep, definitely looks better.
Phenomenal!! 👏🏻👏🏻
Thanks a lot! I really appreciate it!
Turns out I was just stretching the image the wrong way. Just by stretching better and then equalizing the histograms, the color suddenly appeared. A few minor adjustments in curves to balance out the color of the background got rid of the blue cast.
I didn't even need to use color masking, though it was good to learn a new technique
Well Written Respectful Concise Supportive
