Affordable LRGB filters, suggestions?
7 replies373 views
Daniel Renner avatar
In a week or so Im going to buy a 2600mm pro together with filterwheel and filters.
I have chosen Antlia 3nm 36mm SHO filters and I need to find some LRGB filters also that doesnt cost to much…
Got any suggestions?
Antlia LRGB 36mm filters cost 395 euro, are there any cheaper filters that is equal to antlias LRGB?
Andrew Ford avatar
What scope are you using? does it need careful backspacing considerations or has a coma corrector/field flattener? If so, make sure you purchase filters which are the same glass thickness as your SHO filters - this is because you will need to account for (1/3rd) the filter thickness when shimming your backspacing.
FWIW I personally have Baader LRGB and SHO filters and have zero complaints.
My scope is an Skywatcher Espit 100. And the filter thinckness isnt that important since im using darks custom in NINA =)
Joe Linington avatar
Filter thickness will matter for focus offset if you ever choose to use that feature. I have and use the ZWO 2nd gen LRGB filters ($199 at Agena Astro for 36mm). Very inexpensive and they work fine with my triplet scope but for my doublet they go to far into the blue spectrum. I am currently saving for a set of Astronomik for my doublet scope.
Shinpah avatar
Daniel Renner:
Filter thickness matters not just for parfocality (which is what you're referencing) but also for backfocus requirement (which is what Boorkus was referencing).
GalacticRAVE avatar
Few issues to consider. filters tickness are 1mm (Astronomik), 3mm (Chroma (I think) and Astrodon), and 2mm (Baader, Antlia, Optlong, ZWO).
Different Filter thickness can produce problems with backfocus (in particular for fast optics) and when you use an OAG. But since Chroma and Astrodon are not really discount, and also Astronomik is similar if not more expensive than Antlia, this is probably not a problem you are going to have. If you stick with one of the 2mm brands, you probably will be fine (I, e.g. mix optolong NB with antlia LRGB, and the focus point is (almost) identical. almost = well within the CFZ).
The other issue you want to consider is the transmission curve. Optolong, Baader and ZWO open up in B quite early, at around 380nm - which is nice (you get more light) for a reflector. But for refracting optics, trouble increases the bluer you go, so having a 420nm cut off like Antlia or Astronomik may be beneficial. For R, the Antlia open relatively late - which has pros and cons. con: you are losing light, pro you cut the more light polluted spectral range (in particular in areas that still use sodium lights).
personal opinion: since you have a refractor, you probably go best with the Antlias. YMMV.
Matthias
Helpful Insightful
Marc-Antonio Fischer avatar
I got the ZWO onse. they are very good for the price.
NAG avatar
Sometimes "cheaper" leads to frustration.
Astronomik Deep Sky's new filters are very good, but I completely agree that you have to worry about back focus.
If you are happy with the narrowband Antlia filters, maybe I would also choose the broadband Antlia filters.
Opinions and Reviews for the Optolong LRGB set
Hello fellow astrophotography enthusiasts, I'm seeking your opinions, especially from those who use the Optolong LRGB set in their mono astrophotography setups. I'm in the process of renewing my entire set of LRGB and SHO filters, and I'v...
Optolong LRGB set review relevant to author's filter search needs.
May 30, 2025
Review: ToupTek 36mm LRGB and SHO Filters.
Thought I'd share my thoughts about the ToupTek Astro filters I've been using. Brilliant budget friendly filters. ToupTek Astro 36mm LRGB + SHO Filter Review. Introduction.We all know how expensive astronomy can be. Further to that, we all kn...
ToupTek budget-friendly 36mm LRGB filters directly address cost concerns.
Mar 27, 2025
