Search engine
1 reply•66 views
Rich Sky avatar
I am trying to extract all M51 SCT images, that are created with Celestron Reducer f/6.3, using a color CCD camera, in bortle index 8.
How would the search field look like ?
My image should come up, but I got this instead?
What am I missing.
Thank you for your help.
Salvatore Iovene avatar
Hi Rich,
here is the reason why your search is not resulting in the desired result:
  1. You searched "M51" while your image says "M 51" (yes, AstroBin should probably be a bit smarter in that case)[/*]
  2. You limited your search to the "Description" field instead of letting it search over all available data)[/*]
  3. Your camera is probably not classified as a CCD (you need to edit in your profile to specify that)[/*]
The following search does return your image:
https://www.astrobin.com/search/?q=M+51+SCT+Reducer+Color&d=i&t=allAs I mentioned before, the forum is not the place to get users support.
Once more, please read this:
https://www.astrobin.com/forum/c/astrobin/annoucements/how-to-get-customer-support-issue-reports-feature-requests-account-problems-etc/I will close this topic too.
This topic is closed to new replies.
