Steve Steele avatar
Hi Everyone,
I've taken a few images now and i am enjoying it. I'm not yet ready to buy a telescope, but I am ready to buy a small portable astrophotography setup.
I am thinking of the following
  • iOptron SkyGuider Pro[/*]
  • ZWO ASI290MM Mini Camera[/*]
  • ZWO 30F4 Guidescope[/*]
  • Possibly William Optics base for SkyGuider Pro.[/*]
  • Sturdier tripod than the cheap one I've got now.[/*]
I've been looking at options that would help with polar alignment such as ASIAir or the iPolar add on for iOptron. I don't think it works fully with Sony Cameras (A7iii).
I'm also in the process of moving house to a tiny town on the coast with bortle class 2-3 skies . The view to the south from my yard is partially restricted by trees. I can see the SCP but the area arould it is partially obscured by trees and i'm wondering if the alignment camera  will see enough sky around the pole to complete the alignment. Here is a quick star trail pic i took to help determine the SCP location from the deck.
https://astrob.in/2b93r4/0/
i guess my main questions are...
Is the equipment selection a good choice?
Will  the iPolar or similar cope with the trees to the south when polar aligning?
Has anyone got the ASIAir to work fully with a Sony Camera?
Thanks for any advice.
Steve
Steve Clark avatar
You might try starting out without the guide camera and scope as you can always add them later. Less cost involved starting out and you may find that your camera lenses are not giving you the sharpness you want and decide to spend some money on something like a RedCat 51mm or other small ota.
I have the iOptron Skyguider and once it is aligned it guides excellent without a guide/scope camera.
Steve Steele avatar
Hi Steve,
Thanks for the advice, I was thinking that I might try unguided first.
As for lenses, photography is a relatively recent hobby of mine so I have a few camera lenses to buy first  as they are far more versatile if i want to shoot landscape or wildlife. I have looked at the William Optics gear and likely will end up with one of their lenses in the future.
There is only so much i can get past the "master of coin" in one go.
Cheers
Steve
Respectful
Steve Clark avatar
Yep most of us are in the same boat. smile
Who uses SharpCap to do polar alignment with their main imaging camera?
Just wondering if anyone does this? I've just moved my guiding camera to an OAG and it has a really restricted FOV. I used to use it for polar alignment when I had it connected to a separate finder scope, but now I am left with my main camera tha...
Discusses polar alignment methods relevant to author's setup considerations.
Apr 15, 2022
Polemaster vs TPoint for polar alignment
I've just purchased a Polemaster polar alignment camera to use in conjunction with Software Bisque's SkyX-Pro TPoint modeling software. I'm using the Paramount MX+ mount and I most always get Excellent polar alignment results from the acc...
Directly addresses polar alignment tools author is evaluating for their astrophotography.
Feb 12, 2022
SkyMemo tracker running slow -- add an ASIair autoguider?
I'm using a Kenko SkyMemo S tracker, Redcat 51, and Sony a7iii as my primary setup. I'm just now building out my setup; portability matters and my budget is limited, but I'm going piece by piece. With this load, for the last few sessions,...
Discusses portable tracker setup with autoguiding similar to author's planned configuration.
Nov 7, 2021
Skywatcher EQ5 Pro or Ioptron CEM25P EQ? Plus telescope choice.
Hey everyone! I am currently looking at going for a proper Astrophotography setup as apposed to my little DSLR lens and Ioptron Skyguider Pro setup. First things first is the choice of mount. I am tossing up between a Skywatcher EQ5 Pro or the Ioptro...
Covers small portable equatorial mount selection; relevant to beginner mount considerations.
Jul 5, 2019
Hi, from Phoenix, AZ USA
Hi, I'm Keith. I'm a guy that's starting to get more serious about astrophotography. It's more of a sedentary hobby I can see myself capable of doing as I grow older. Right now, I'm 42 years old. This seems like a pretty casual, a...
Getting started guidance for astrophotography with equipment considerations.
Dec 19, 2018
