A versatility of the Askar FMA230 rings.
9 replies338 views
Vroobel avatar
Everybody interested in the Askar FMA230 had to see threaded holes on each of the four sides of the rings. I decided to use them all.
All my scopes have the ZWO EAF attached, so I ordered the Deep Sky Dad's kit for the EAF as well. It's placed on one side. The FMA230 can be easily rotated in its rings, but not with the EAF attached. There is 120:1 gearing in the EAF, so rotating its axis is impossible. Therefore, if you rotate the scope, you change focus. It shouldn't be a big change, but rotating the scope 90 degrees means rotating the focuser ring 90 degrees in the opposite direction.
After some experience with framing, I found that the best result (for me) is if the DSO fits the frame with the horizontal or vertical orientation of the camera. Here is the place for the extra dovetails. My ASIair Plus, home-made smart dew heater controller and also SW Evoguide 50ED are equipped with dedicated ZWO Vixen-style clamps. All my scopes have extra dovetails for ease of attaching the accessories. I figured out that if I screw the FMA230 on the saddle using the side dovetail, I can get the vertical composition and I'm still able to attach my accessories around. Yes, I know, that's crazy, but I'm... lazy...
To be able to screw the two extra dovetails you need some M6 and M5 bolts. Additionally, the side opposite the EAF requires a few mm thick spacers, because a timing belt pulley from the EAF kit makes the screwing impossible. I designed and printed the relevant spacer, so after applying it, everything is OK.
I'm hugely impressed by the EAF kit. I have a big experience with 3D modelling and prototyping, so I can appreciate the cleverness of the solution. The kit moves together with the focusing ring. I thought I can do it and safe £129, but not, I wouldn't do it so well with a significantly lower cost. Thus, well done, Deep Sky Dad!
There is something to do with the EAF kit, but first I have to do it and then will write about it. Deep Sky Dad should take it into account.
Larry Cable avatar
hey do you happen to know the specs for the bolts needed to attach to the side mounts on the FMA rings?
M? and length?
Vroobel avatar
Hi smile
I'm sorry, I don't remember.  I can check it later, but the rig is in use at this moment so I don't want to disassemble it when the good weather may happen at any random time.
Arny avatar
nice versatile solution!
Vroobel avatar
Larry Cable:
M? and length?
There are holes of two sizes: 2x M5 (8mm deep) and 1x M6 (7mm deep) on sides of each ring. Length of the bolts depends on a thickness of the addition which you are going to attach there. I hope you find it helpful.
Larry Cable avatar
Larry Cable:
M? and length?
cheers @Vroobel just what I needed ... many thanks, you'd think Askar would mention this on their product description!
BTW I used my FMA230 for the 1st time last night ... I definitely think that the 55mm back focus as documented is wrong, I can definitely see some elongation of the stars in
the corners not too mention perhaps a hint of vignetting too!
apart from that very pleased with the little scope!
thanks again! much appreciated!
Larry Cable avatar
BTW I plan to attach 2x Askar 90mm multi-connection finder plates using the central M6 I think
Vroobel avatar
After many tests I stopped with 52.5mm of the back focus. I have no idea why it happens. Now I'm very close to round stars in corners.
Good luck. 🙂
CS, Martha
Larry Cable avatar
Good luck. 🙂
CS, Martha
I'll try that thx
Larry Cable avatar
Review of Askar SQA 55 after 6ix month use
Summarize the advantages and disadvantages of SQA 55 Advantages No coma, no back focal length problem, and the surrounding stars are very round. As long as you can focus, you don't have to worry about the BFL like other comma correctors. The 2-in...
Reviews other Askar products; may discuss similar mounting/attachment issues.
Jul 14, 2025
Scope slips in mounting rings.
Hi everyone. I have a new WO FLT 120. So far everything works very nicely and very happy. However if I point the scope vertically, for example during balancing on the mount, the OTA tends to slip in the saddle rings … which is a bit scary and l...
Discusses scope slipping in mounting rings; directly relevant to ring attachment problems.
Apr 22, 2025
