Object not centered after meridian flip
8 replies431 views
Michael J. Mangieri avatar
Hi all.  I have a question regarding meridian flips and plate solving.
I have an EdgeHD11 on an AP1100 mount.  I use NINA and ASTAP in my suite of software tools.
Last night I started my sequence run of 18x600s Ha followed by 18x600s of Oiii on M27.  I had centered M27 prior to the run. After the meridian flip M27 was offset from center by about 56" (nearly 1 arc min).  Since the coordinates were preset at the beginning of the sequence, I'm not sure why ASTAP/mount couldn't center the object after the flip.
Any ideas?
Björn Arnold avatar
In NINA, there's a setting called "recenter after flip" which you might need to turn on. You'll find it in Options -> Imaging under "Meridian flip settings".
If you work with the advanced sequencer, I recommend also to include the "recenter" trigger which monitors over the course of imaging if the image center has shifted beyond a certain limit and triggers a recenter.
Björn
Well Written Helpful Concise
Brian Puhl avatar
Like Bjorn said, recenter after flip, and then in your triggers make sure you have 'recenter after drift'.   Even if it fails on flip, it will find itself again after X exposures.
I would also add you SHOULD put refocus after flip in your meridian flip settings as well.  If there's any slop in your imaging train, it could get thrown out of focus after flip, possibly causing a plate solve failure
Guiem Kimi avatar
Just to add some info here, logs in NINA give lots of info about what is happening during the session. You can find a button which open it's folder in Options > General > Logging
For example, I had a failed flip in one of the last sessions and thanks to the logs I realised it was because of an EQAscom AR limit misconfiguration.
Clear skies,
Guiem.
Scott Lockwood avatar
I'm not familiar  with NINA but I do have a AP1200 mount. The AP should nail it. My though is- did you finetune the location of M27 after you slewed to it? If so, did you re-sink on the object as if not, the flip would go to the first location.
Oskari Nikkinen avatar
I also use NINA and find that sometimes it is not within tolerance even with the relevant settings ticked (the recenters and such already mentioned). I suspect that for some reason NINA defaults to the default platesolving tolerance (which i believe is 1 or 2 arcmin) after an automatic re-center post meridian flip, whereas you could have set your tolerance to a lower value.
Anyway i have not bothered to look into it closer and just re-center again after a meridian flip and get the correct framing. I am sure there is some more elegant automatic way of doing it, but what works is good enough for me.
Thank you all for your input.  I think I did finetune the location (as Scott mentioned could be part of the problem).  I already have the recenter after flip but will add the  refocus after flip command in my sequence for tonight and see what happens.  In this hobby there is always something new that you didn't know about.  What makes this hobby fun, I guess smile
Scott Badger avatar
If you have re-center after the flip enabled, but don't have the coordinates of your target in the sequence, then NINA will platesolve to the coordinates that the mount thinks it's pointing at, not necessarily the target. I'm not sure why there's a difference, whether it's due to the pointing adjustment after the initial platesolve (before the meridian flip), or the drift while not guiding when NINA pauses the sequence before the flip. Not sure how that would work, but the problem seemed worse when I was imaging in Ha where the longer exposures tend to result in longer pause times. Anyhow, Cuiv mentions it in one of his videos, https://www.youtube.com/watch?v=lAMyEpBcLV4 (at about 15:40). Whatever the cause, adding my target coordinates to the sequence made the problem go away for me.
Scott
Helpful Insightful Respectful
Looks like I may have adjusted the position prior to running the sequence and so when the flip was completed NINA used the incorrect coordinates to center on.  Tried again by using the framing assistant  to get the actual location, saved that as a target and ran the sequence. All is well now.  Thanks everyone.
major issue platesolving after meridian flip
I've recently started using NINA to control my imaging sessions and I've been having this weird issue regarding my meridian flips. Essentially, once my mount executes the meridian flip and does a plate solve it slews back to where it was befo...
Object centering after meridian flip and plate solving with NINA.
Aug 1, 2021
ASTAP Plate Solving Fails in NINA
Last night, and tonight, Nina's advanced sequencer reports that Solve & Sync failed. But in both sessions, everything is proceeding as expected–focus, tracking, star shape and size, HFR all look good. I can't see a problem as NINA f...
ASTAP plate solving failures after meridian flip directly match your centering issue.
Jun 7, 2025
SyncToTarget() RaDec sync rejected
Hello,, A few nights ago I opened the roof of my observatory just like any other night and decided to take a look at M104, which for me in Scandinavia sits very low on the horizon near the meridian. I used the target finder in NINA and my EQ6R-Pro sl...
RaDec sync problems may explain post-flip positioning errors with preset coordinates.
May 1, 2025
