I recently purchased an Edge HD 14" to use for planetary and want to start with Jupiter. The only planetary camera I have at the moment is the ZWO ASI290MC and would like to start off with that. Currently I own the t-adapter for the scope and I have a 1.25" 2x barlow I have used in the past. I am not sure how to set up the spacing correctly. I read that the Edge HD needs 144mm of spacing from the rear to the sensor to get the best quality but I am not sure if this is relevant for quick exposure planetary shots. One possible set up would be the visual back, a star diagonal, the barlow and then the camera. Does the spacing matter after or before the barlow lens? I could also go from the t-adapter to the barlow and then to camera somehow. Does this sound correct? Also, I am considering purchasing an ADC. Will this make a noticeable positive impact? Thank you in advance!
