Eric Maurício avatar
Hello all, I hope you're doing great.
I've purchased the Touptek2600c (tsoptics rebrand) around 2 or 3 months ago, as per usual, the weather wasn't cooperating, so I had to wait arund a month before I could start shooting. My plan for clear nights with little to no Moon, was to shoot the Shark Nebula, and so I did.
After I got around 6h of data, I started to have a go at it in Pixinsight, and the problem first appeared. As I apply the Auto Stretch, I noticed vertical banding with alternating magenta and cyan cast, like so:
This is a 18h stack, with no calibration frames, with ABE and Spectrophotometric color calibration applied, StarXterminator then saturated to enhance the issue.
My acquisition process is as follows: 300s subs, 100 gain, 50 offset, at -15ºC. High Gain Mode enabled, Dew Heather on, although I don't think the camera as one, Ultra Low Noise Enabled. I dithered every frame.
Solutions that I've tried: Obviously I started by including calibration frames, darks, flats, and dark flats, none of them resolved the issue. Then I thought that, since I don't get the banding using the L-Ultimate filter, it could be a filter problem, so I removed the Svbony IR/UV cut filter, tossed all the frames that I had previously taken and shot again. Ended up with the picture above, so I guess it isn't the filter, but I cannot reproduce the issue, using the exact same acquisition process and stacking, with the L-Ultimate filter.
This is around 9h with the same acquisition and stacking technique.
Since I'm aiming at an LDN, I thought that it could also be that I'm clipping my blacks, so I increased the offset to 200, same result.
Then, I tried with 60s, and after that, 120s subframes, because I could probably be saturating the pixels and getting the pattern as a result, nothing changed.
I debrayed a single frame, stretched it, and the pattern (I think), is barely visible.
My theory is that pixels that don't get enough signal tend to form a patter noise with those colors, it's the only thing that I can think about, but I have no idea anymore, dark frames should enhance the issue and correct it.
300s dark frame, debrayed, stretched.
If anyone as any idea what the problem seems to be, or as any input on the situation, I'd love to hear it.
Thank you and Clear Skies.
wittinobi avatar
if you use NINA, you can try to decrease the USB-Speed to 2 or 1.
Best Regards
wittinobi
Best Regards
wittinobi
USB speed was set to 2, will try 1, hopefully I can get some hours tonight and see if it helps.
Thank you!
Shinpah avatar
I know several people, myself included, who have had horizontal banding appear in touptek 571 (Risingcam) cameras. Dark frames don't correct it because it jumps around from exposure to exposure. One of them (https://www.astrobin.com/users/justintastro/) had his banding go away from changing the USB traffic setting in NINA only for it to come back again with a vengeance months later - updating NINA to 3.0 for him has fixed it so far (which doesn't really make sense, but if it works it works).
Starxterminator will also make colorful tiles in your images if you push the data too hard - so make sure you're not inducing banding in that manner.
Maxim avatar
Hi Eric! Did you manage to resolve the issue? I'm having the same problem with the same camera
Maxim avatar
My banding pattern is visible the best on flat images(mind the dust speck, I've just unscrewed and screwed the camera). The worst part that it's not so strong(if exists at all) on the light images, that's why when I stack without flats, the image is better off, at least no visible banding is there. But these kind of flats ruin the stack, while correcting the vignetting and the dust. I've tried all the possible settings, usb speed, readout mode, ultramode etc. Even connected it to usb 2.0. No success whatsoever.
Noah Tingey avatar
Maxim:
What is your exposure time for the flats? Too short of an exposure time can, on some cameras from some manufacturers, cause the camera to enter a different mode. QHY's drivers call this the "Stream" mode, for example. A common rule of thumb that I've seen is that you should aim to have your flat & bias exposure times above 0.2s to avoid these modes, though the exact cause (and exact minimum exposure duration) are not fully known.
(For the nerds: Note that this is distinct from the camera's readout mode. Stream mode is a separate phenomenon. This is also different from the ASI1600's weird behavior for exposure times under 0.2s).
Brian Puhl avatar
Are you sure this isn't a light source issue?  I've never seen vertical banding before.
Maxim:
Hi, Maxim!
I worked out the issue by correcting my flat frames, which I didn't at the time, or didn't do correctly, the banding appeared only in the flats, which, if left uncorrected, would result in the banding. So I took darkflats after my flats, stacked them as "bias frames" in Pixinsight, and managed to eliminate the banding.
Maxim avatar
Noah Tingey:
(For the nerds: Note that this is distinct from the camera's readout mode. Stream mode is a separate phenomenon. This is also different from the ASI1600's weird behavior for exposure times under 0.2s).=14pxBrian Puhl (WhooptieDo)
Thanks for the answers! It's 0.24s now, but I've tried even with up to 9 seconds to also exclude the flat panel refresh rate or something. Anyway flat panel shouldn't be an issue cause there's no banding when I used it with my 533MC.
Eric Maurício:
Maxim:
Hi, Maxim!
Interesting! How did you come up with this? So you take flats, then darks with the same exposure time and then feed darks as bias into WBPP? I tried it with the data I had and nothing changed Can you please provide more details, maybe specific camera settings and exposure time?
Guiding issues or something else?
Hi all, Yesterday I finally assembled my setup after 2 months - nice feeling to be with rig again Unfortunately the real night here starts only at 23:00, so it's quite though to do all normal tweaking of the setup. After the normal setup (polar a...
Calibration issues can cause banding; guiding problems affect image quality.
Jun 17, 2025
Two Questions Regarding Pre-Processing in Pixinsight
I made two problems for myself: 1. I didn't make my bias frames the same temperature as my lights, the lights are at -10c and the bias frames are at 0c. Darks are same temperature as lights. Is there anything I can do to compensate for this other...
Bias frame temperature mismatch causes calibration errors and artifacts.
Dec 2, 2024
Issue in frames calibration?
Hi everyone, this is a long post, but it’s needed to provide proper context. Thanks in advance to anyone willing to read through it and help me figure things out! I’ve been struggling for days with what seems to be a calibration issue (or possibly a ...
Frame calibration problems may explain vertical banding in processed images.
Jul 8, 2025
Flat Darks prep and use in PI
Recently, I switched from the ASI 2600MC to the ASI2600 MM Pro with LRGB filter wheel. It's been a complicated journey for sure. Im trying to figure out dust motes, flats etc and was really stumped. I often find numerous dust motes in my my linea...
Flat darks preparation relevant to calibration workflow in Pixinsight.
May 25, 2025
What reasons could affect Flat Frame performance?
Dear Friends, I require assistance with flat frame acquisition. It looks like my flat frames overcorrect the images and specifically in the green channel. I dont understand what the problem is! I had this issue before but usually the problem was ligh...
Flat frame issues can cause channel-specific artifacts and banding.
Feb 1, 2025
