Jerry Gerber avatar
Should I calibrate my flats with darks as well as flat darks or bias frames, or is it not necessary to calibrate flats with the same darks I use to calibrate lights?
Jerry
Quinn Groessl avatar
Flat darks are  basically darks for your flats. So that's all you need.
Christian Großmann avatar
Hi Jerry,
as far as I understand, it is a matter of the exposure time used to create the flats. I personally use a Flat panel and the exposure times for the flats are way less than half a second for LRGB and around half a second for narrow band. So I am not concerned about flat darks, even with the heavy amp glow I see with my sensors on long exposures.
Otherwise, If you do skyflats for example, the exposure time might get quite long. Then you might think about calibrating your flats. Where the exact border is depends on the sensor, the exposure time and maybe some other stuff. If you look at the infos that many of the photographers give when they puplish their images, not many of them seem to do flat darks.
But try for yourself. If it improves your images, it's worth the effort. If you do flat darks and they won't improve your images, they won't hurt either. If you build yourself a dark library under controlled and repeatbale conditions (i.e. cooled camera and flat panel), you may reuse them for a longer period of time.
Clear Skies
Christian
Arun H avatar
There are two ways you can do this:
Method 1:
Subtract a master dark of the same exposure length and temp as your flats. Example: You use 4s flats at -10C. Calibrate them with a master dark constructed from 4s flats at -10C. With this method, you don't need to worry about bias (since your master dark already contains the same bias  as your flats). It will work with any camera, but you do need to have a library of darks of the same (or close) exposure time as your flats.
Method 2:
Do not worry about darks at all and simply subtract a bias at the same temperature. Example: You have a 4s flat at -10C. Simply subtract a bias taken at -10C and don't worry about darks. This method is a bit less accurate than Method 1 since it does not account for the small amount of dark current built in the exposure time of the flat. As long as your flats are only a few seconds long, this should not make a huge difference. However, some cameras have artifacts that make taking a true bias impossible or at least very complicated, so for those you should use Method 1. Cameras with amp glow may also create issues with this method.
Whatever you do, do not calibrate flats with the same darks as your lights.
Well Written Helpful
Jonny Bravo avatar
You use either… darks (called dark flats or flat darks when you take them to calibrate flats) or biases. You don't use both. Debates rage over the effectiveness of one over the other. Owning a 294MM, I always take longer flats with matching darks. I do not use bias frames.
Two Questions Regarding Pre-Processing in Pixinsight
I made two problems for myself: 1. I didn't make my bias frames the same temperature as my lights, the lights are at -10c and the bias frames are at 0c. Darks are same temperature as lights. Is there anything I can do to compensate for this other...
Bias frames must match light temperature; relevant to flat calibration requirements.
Dec 2, 2024
Flat Darks prep and use in PI
Recently, I switched from the ASI 2600MC to the ASI2600 MM Pro with LRGB filter wheel. It's been a complicated journey for sure. Im trying to figure out dust motes, flats etc and was really stumped. I often find numerous dust motes in my my linea...
Directly addresses flat darks preparation and use in Pixinsight.
May 25, 2025
Issue with flat frames
Hello everyone, I need some advice about flats. A few months ago, I switched to a monochrome camera with an IMX571 sensor (ToupTek ATR2600M), paired with a ToupTek filter wheel and Antlia LRGB filters. As my main telescope, I use an Askar 103 APO. I ...
Discusses flat frame issues with monochrome camera; calibration relevant.
May 6, 2025
What reasons could affect Flat Frame performance?
Dear Friends, I require assistance with flat frame acquisition. It looks like my flat frames overcorrect the images and specifically in the green channel. I dont understand what the problem is! I had this issue before but usually the problem was ligh...
Explores flat frame performance problems and overcorrection issues.
Feb 1, 2025
Pixinsight - Calibration
Does anyone know why I should get the attached error message in PI when I did in fact have Darks/Bias/flats but it's not using the darks for calibration! Thanks Jonathan Screenshot 2021-12-09 at 21.48.26.png
Directly addresses dark frame calibration for flats and bias
Dec 9, 2021
