Ratio between RGB and L data
13 replies861 views
Christian Bennich avatar
Hi all
Are there any “golden” rules or ways of defining how much RGB vs. L data is needed on a target?
Miguel T. avatar
Nothing based on science or any golden rule but I do between 2x and 3x more time on L than RGB with very great results.
6h of L and 2h of RGB would be some of my typical numbers.
Concise
1:1, same scale.
tjm8874 avatar
Basic theory is, if you have 6 hours, take 3 hours L 50% + RGB 3 hours (1 hour each) 50%
for Colorful nebula : increase RGB %. (2 hours L + RGB total 4 hours)
for dark and distance galaxy : increase L %. (4 hours L + RGB total 2 hours)
1:1, same scale.
@andrea tasselli - by 1:1 do you mean the same total amount of RGB as for L?
Shinpah avatar
I think for these discussions it's important to really quantify with examples.
Saying 1:1 L to RGB might mean they take 3 exposures of L and 1 exposure each of RGB (LLLRGB). They might also mean they take 1 exposure of L and 1 exposure each of RGB (LRGB).
Good point @Shinpah
Christian Bennich:
1:1, same scale.
1 hour for 1 hour of RGB (each). Then add the RGB and put that as L.
[deleted]
Wrote a little time exposure app that can guide you based on desired SNR. You can get a good sense by comparing exposure time per filter.
https://clearskies.go.ro
Sometimes I get power cuts and the site goes down, but there is a download link for the standalone windows version.
Mickaelle (kaelig) avatar
For my point of view, for:
LRGB: 3h of L for 3h of RGB
SHO with LRGB stars: same time for each LRGB max (between 30 mn and 1h) with SHO (upper than 10 h)
Scott Badger avatar
I shoot for twice the number of L as for any one of R,G, or B, i.e. if I get 100 lum's, then I'm looking for 50 each of R, G, & B. But that was just a guess at what 2 to 1 meant when I saw it recommended way back when.... Also, I realize it's really more about exposure time than number of subs, and my Lums are typically 240s and RGB 300s, but since it's all a bit arbitrary anyhow, number of subs is easier to keep track of.... : )
It's certainly possible that what was meant was twice as many Lums as R, G, & B combined, so 300 lums for my 150 RGB's, which if you're getting the detail from the Lums and just painting color on top with RGB's probably makes better sense..... More exposure time means more detail, but how does exposure time correlate with color?
Alternatively, does it make any sense to skip Lum acquisition altogether, use a synthetic Lum for processing, and invest the saved time in more RGB?
Scott
Arun H avatar
Scott Badger:
Since the luminance filter captures roughly three times the photons per unit time as any one of the RGB filters,  a synthetic lum constructed of RGB will have much less SNR than the lum filter in the sameimaging  time. So this isn't a great idea and defeats the benefits of LRGB imaging.
I also use the 50/50 rule, i.e., 50% of time on L, 50% of time on total of RGB. This means the L image as roughly 1.7 times the SNR of the RGB. If have often felt that this is not adequate, i.e., have wished for more RGB time. One technique to improve the color SNR is to use an OSC for color capture (if imaging from a dark site) since the OSC is more efficient than mono for RGB. The LRGB images I am happiest with had their color data taken with an OSC.
Kevin Morefield avatar
I like to use about 2x the L of each color channel.  So 3 hours each of RGB I'd do 6 hours of L.  And then almost always create a SuperLuminance from the RGB and L masters.
How that varies depends on the target, the data quality and what processing challenges I'm having.  If it is a faint object that is not super colorful I might go with more Luminance.  For really bright objects where the color really defines the object I might use 1:1:1:1.  For star clusters I don't use Luminance because the goal is to retain star color as best as possible and there is no challenge of capturing enough light.
I guess it works out like this:
3:1:1:1 = Faint galaxies and nebulae like M64
2:1:1:1 = General targets
1:1:1:1 = Very bright colorful objects like M20
0:1:1:1 = Star Clusters like M13
Kevin
Shinpah avatar
Arun H:
Scott Badger:
We've briefly had a discussion in the past r:e OSC vs mono rgb efficiency, but I'm not confident in the complete accuracy of the spreadsheet/CN thread used for that assertion (or at least in one particular case - the 571 QE curve).
To answer the poster:
For LRGB imaging I do 2:1:1:1 LRGB and integrate all the exposures together to use as the luminance data.
I think there's pretty questionable use in a 1:1:1:1 ratio if you're solely using the lum by itself since it probably won't be particularly less noisy than the luminance data from the RGB subs.
Review: ToupTek 36mm LRGB and SHO Filters.
Thought I'd share my thoughts about the ToupTek Astro filters I've been using. Brilliant budget friendly filters. ToupTek Astro 36mm LRGB + SHO Filter Review. Introduction.We all know how expensive astronomy can be. Further to that, we all kn...
Discusses LRGB filter ratios and practical filter usage for astrophotography targets.
Mar 27, 2025
Combining image data with different f ratios
I'm looking for advice suggestions on how to combine data between systems with differing f ratios - in my case specifically f/1.9 with f/7.9. For example 5 hours at f/1.9 with 10 hours at f/7.9. Creating a single stack of all data doesn't see...
Addresses combining different data types and technical parameters for imaging optimization.
Apr 27, 2025
binning, f-ratio, pixel-scale, drizzle, onag vs oag and the consequences for my next imaging setup
Fellow friends of the night sky, Just two months ago, I opened a thread asking for your opinions on which scope to buy. Today, I’m back with a similar goal. I’m willing to invest a significant amount of money to either complement or replace my existi...
Covers imaging setup parameters including pixel-scale and technical considerations for data acquisition.
Dec 15, 2024
