Christian Bennich:
Thx @andrea tasselli - I am working my way towards understanding tilt and how to correct it.
For my benefit - which indicators are you specifically looking at when you point to spacing?
Does the tilt part give itself away in the FWHM measurement?
I currently image with this GPU unit - https://www.teleskop-express.de/shop/product_info.php/info/p6706 but were looking for something that could also allow for a slightly bigger fov as well.
I would assume that the GPU suffer from the same tilt as the Nexus.
Until now I have postponed working on eliminating tilt as I am waiting for an upgrade to my focuser - but Baader is unable to deliver at the moment.
Thank you for your feedback.
Normally, if it is just tilt, some areas are in focus with no aberrations while opposite areas have them, mainly astigmatic coma. One typical situation is a tilt about one of the main diagonals of the camera, wherein you have good roundness along one diagonal (and the center) while the two other opposite corners show elongation in opposite directions. In case is both spacing and tilt, than you should also see some residual coma just off the axis along one side showing less of it and one side showing more of it. In your case I think you also have some collimation issues (slight flares on stars about the centre). Issue with tilt are best righted using something like Gerd Neumann's CTU unit, not by changing the focuser (which carries risks in itself).
@andrea tasselli - that CTU does indeed look very nice. I am somewhat limited in my imaging train. I have the ASI2600 + filter wheel + OAG-L + a 5mm tilt plate - that adds up to 55mm - I can't see any way to free up enough space to put in such a CTU....unless I remove my OAG and go back to a "normal" guide setup.
After switching to an OAG my guiding has dropped to between 0,4 and 0,7 arcseconds - which is waaaaayyyy better than I could achieve before.
So I guess I will have to fix my tilt with the current tilt plate....unless there are Astro Jedi tricks I have not yet learned?
Another follow-up question:
In your initial answer, you also mentioned spacing - if I "do the math" on my imaging train that look like this:
It does NOT consider the 2mm filter in the EFW - which means I must be 0,66mm off in my back focus - is that correctly understood????
To solve this - I would need to add 0,66mm of spacing between my tilt plate and my GPU.
If I understand it correctly - I would then need some M48 spacers - as the threaded connection between my CPU and the OAG as M48 - I can only seem to get 0,5mm and 1mm - so I can choose to add 0,5mm - which will still leave a "gap" of 0,167mm or add a 1mm spacer and introduce 0,33mm difference in the other direction.
I would assume I should go for the solution closest to 55,66 mm back focus - meaning adding the 0,5mm spacer.
Long post - thank you in advance.
