Auto guide setup for Orion ED80mm
2 replies70 views
mousta avatar
Hello everyone,
I have an Advanced VX that I’m using with an Orion ED80 and Celestron Stransense camera for quick alignment.
I taking good pictures so far, however since my mount is old, I think I might be needing an auto guider. i looked at the Orion 50mm since it’s small, but Im not sure if that compromises the performance.
does the size of the guide scope matter ? For the camera I think I’m set on the ZWO ASI290mm mini.
Also, given my main imaging telescope is small and I already have the starsense camera on the back end where the regular finder scope used to be, any suggestions on where/how to mount a guide scope ?
Thomas avatar
I have the Orion ED80 and use a 50mm guide scope with an ASI224MC and it works great. Had the 224 for planetary work and instead of buying another guide cam, decided to give it a try and have had no problems. In terms of mounting, I have another dovetail bar mounted on top of my tube rings that I attach the guide scope to. This leaves the finder scope spot on the scope free to use with the finder scope.
Thomas avatar
You can see the whole setup here:
Setup
Newbie from Bortle 8 London UK
Hi Everyone, About 50 years ago, I was a keen amateur astronomer in Melbourne Australia, and I'd like to get back into astronomy and astrophotography, but boy have things changed in 50 years! I'd like to be able to image DSO, the larger plane...
Returning astronomer seeking guidance on equipment setup and best practices.
Oct 31, 2021
Should I upgrade my mount or my guiding camera?
I have an HEQ5 Pro mount and a Skywatcher 200dps with coma corrector (That's an F4.5 906mm Newtonian effectively). I guide them with an Orion Starshooter system. I regularly get 0.85 arc secs RMS via this setup which is equivalent to the resoluti...
Directly addresses mount upgrade and guiding camera selection decisions.
Mar 26, 2022
Using two telescopes on the same mount: Piggy-back imaging
For long, I have been using a small Takahashi scope (FS-60C) as a luxury guide scope for a larger 100mm refractor. The small Tak was mounted on top of the refractor and has served its purpose very well, providing pinpoint stars to the guide camera. R...
Discusses guide scope setup and piggyback configuration on same mount.
Oct 22, 2021
