HEQ5 and WO ZS73 — What's the best option for scope upgrade?
5 replies174 views
schmaks avatar
I will eventually want a more powerful scope (longing for greater detail in my shots already) what would the next be? I am looking at the ZS126 or perhaps the 103. I am hopeful I can upgrade the scope without upgrading the mount.
Thanks for the input!
Richard avatar
Hi Schmaks, I went from the Z61 with a Skyguider pro to the z103 and HEQ-5 pro this year, with the Field flattener for the Z103 you have a 0.8 reducer, so you are getting a much bigger scope with only about double the focal length + faster F. I am very happy with the Z103 and it works great on my HEQ5 pro mount. Roll over to my page to see results ( i m by no means as talented as most on this site but it gives you a starting point). One thing I have noticed though through all my equipment buying is you ve got to be absolutely sure everything is going to work, so you are doing the right hing and asking! I am taking in some cases 600s Subs, and I m sure I can do more ( i ve already prepared the 900s dark frames). Or for a big boost without going all out on a new scope is guiding. I personally think (because i m afraid to go down the laptop route) an ASIair and a guiding cam brings a heck of a lot to the imaging in tracking and longer exposures. Hope that helps a little! Z103 is well worth it, but I think after adding all the accessories I'm pushing 50% of the weight limit of the HEQ-5 Pro and I m not going to go over it. Next stop a new mount! smile
schmaks avatar
Richard:
Thanks! This is a good reference.
dkamen avatar
Hi schmaks!
Out of the two, I would only consider the 102.
There is a very large difference in size and weight between 102mm and 126mm. For photography these factors matter more than aperture because they affect tracking and guiding accuracy which you becomes more important the larger the focal length. The heq5 has a nominal capacity of 13.5kg, so maybe 8 for imaging. I just don't see it coping with 10kg worth of scope.
This is why most people never go above 100-106mm refractors.
If you want to aim that high there are much better options in the form of reflectors and catadioptrics IMO.
You should also consider whether that detail is actually achievable with your average seeing conditions. You might find that things at 800mm focal length are just fuzzy 2x versions of things at 400mm.
Dimitris
Helpful Respectful Concise
Refractor suggestion
Hi everyone! I am looking for suggestions for my refractor. This refractor will be on EQ6-R mount. I'll be using the ASI294MM and Astrodon filters on it. I love to see round tight stars on my images (which I am struggling). I am looking to image ...
Author seeks scope upgrade advice; similar refractor recommendation discussion.
Feb 28, 2022
Help me pick a new Refractor! ~600mm at ~f/5.6 reduced or native
Hi everybody, I‘m in the market for a new refractor. I want to get deeper into galaxy imaging and my current 80mm f/7 ED Doublet is a little limiting in terms of image scale and resolution, even paired with the 183MC Pro. I really don‘t want to get a...
Directly relevant - discusses upgrading to longer focal length refractor for better detail.
Oct 20, 2021
Longer focal length Scope suggestions requested
Am looking to get a Scope with a longer focal length. Have the following gear already: Scope: WO Zenithstar 73 + WO FLAT73R Flattener/0.8x Reducer Mount: iOptron CEM25P (CEM70 is already on its way to replace this) Camera: ASI183MM pro Control: NINA ...
Author asking for longer focal length scope suggestions with existing gear listed.
Oct 1, 2021
Advice on paring a William Optics Zenithstar 61 with a one shot colour (cooled) CCD Camera
Hi all. I am currently paring my William Optics Zenithstar 61ii (Z61) with a DSLR (Nikon D750). While I am still a beginner, the more I practice and the more I learn about imaging and processing, the more fussy I am becoming with the results. So far ...
Discusses pairing William Optics Zenithstar with camera; relevant to scope upgrade considerations.
Aug 10, 2021
Time for a new scope, maybe - need some feedback (WO Fluorostar vs Esprit ED)
Hi, so I just broke my Newtonian, after fiddeling with it too much. Been having trouble getting the collimation to stick for the past two years. Every night I would nervously check the first images to see if everything looks fine. Half the time it di...
Scope upgrade decision between specific models; similar upgrade planning context.
Sep 9, 2021
