Windy! Weighing down Mount?
6 replies154 views
schmaks avatar
It has been incredibly windy around here and I am worried to leave my scope/mount running without watching it. Has anyone encountered this issue? What can/should I do to weigh it down? Sand bags or something of the sort?
I have a ZS73 on top of a HEQ5.
Scott avatar
If it is windy enough to topple your mount then why risk using it?  It sounds like you are imaging as well and I would not expect to get good data in those conditions.  If you must use it, then sandbags placed around the legs might work.  Good luck.
Scott
Well Written Concise
schmaks avatar
Scott:
If it is windy enough to topple your mount then why risk using it?  It sounds like you are imaging as well and I would not expect to get good data in those conditions.  If you must use it, then sandbags placed around the legs might work.  Good luck.Scott
Interestingly enough, here in TX—it can be clear skies with big gusts of wind here and there—especially as temperatures are changing.
I'll see if I can find a sandbag suitable.
Sigga avatar
I live 1/3 year one of most windy places on planet. Even if weight down tripod wind vibrate the gear, I had whole hours of imaging unusable due to wind, my suggestion don't waste time and take chance something bad occur.
Sigga
schmaks avatar
Sigga:
I live 1/3 year one of most windy places on planet. Even if weight down tripod wind vibrate the gear, I had whole hours of imaging unusable due to wind, my suggestion don't waste time and take chance something bad occur.Sigga
Thanks, Sigga.
Where I am, it can be very calm then we get big gusts... then nothing for hours. So, I think I need to get some sandbags to weigh down the mount—and then really review my shots well to see if the wind ruined any shots.
Sigga avatar
Sigga:
Thanks, Sigga.
No, Ísland dead calm, then wind 100km in 5 minutes, Føroyar worse.  Be smart and if any concern stay inside. Someone may wish carry outdoors gear, sandbags, ground stakes etc and take chance, not me. This also not take into account dirt, snow and such blown on lenses or debris hit and damage  gear.
Sigga
schmaks avatar
Sigga:
Sigga:
Thanks, Sigga.Where I am, it can be very calm then we get big gusts... then nothing for hours. So, I think I need to get some sandbags to weigh down the mount—and then really review my shots well to see if the wind ruined any shots.
Sigga
Surely—I am being careful. All of this is in a back yard on a concrete pad. Photos to come!
Keeping telescope protected and dry when permanently mounted outside under a cover
For the past 12 months I have kept my pillar mounted, 8" Newtonian dry without scope, mirror or mount deterioration, while enclosed in a TeleGizmos 365 series cover. I have weighed down the pillar with sand bags and tied the cover tightly at the...
Permanent outdoor mounting protection relevant to securing equipment in windy conditions.
May 21, 2021
Requesting experienced opinions on the Mach2GTO with 2 axis encoders
Hi All, I am considering the Astrophysics Mach2GTO with the absolute encoders for a pier mount within an observatory (design TBD). I want to use this to run a survey rig, with a 12 inch imaging Newtonian that will move between multiple targets each s...
Large mount discussion may address stability and wind resistance for telescope setups.
Jan 11, 2022
EQ8-R Pro - problem with worm drive
Hi, I just got a brand new EQ8-R Pro - unfortunately, the mount is not working out of the box. Specifically, after loading the scope etc and starting the star alignment, the RA axis (I think) made a terrible grinding/screetch noise, not always, but i...
Mount mechanical issues could relate to securing equipment against environmental stress.
Oct 16, 2021
