Filter Suggestions for QHY268C w/LX200GPS 10" under Bortle 7-8
7 replies439 views
chefjedidiah avatar
G'day All,
Asking for suggestions for the above combo.  I am OAGing and binning x2, and am wondering what the community would recommend for filters, be it in a drawer or on a wheel.
Thanks,
Jed
L-Pro for broadband and L-eXtreme or ASKAR ColorMagic Duo (6nm)  for narrowband.
Zak Jones avatar
I agree with Andrea's comments about the mentioned filters.
I can vouch for both filters, they are excellent choices. If you don't like the halos caused by the L-eXtreme, there is also the Antlia ALP-T. It's bandpass is 5nm compared to 7nm on the L-eXtreme and from what I have seen it doesn't produce any halos or if it does, they are nowhere near as bad as the L-eXtreme.
There is also the Optolong L-Ultimate, which is again 2nm tighter at 3nm, although from what I have seen it does produce halos depending on the situation and the target you image.
Another broadband filter that might be worth considering is the Antlia Triband RGB. I don't know if it's a "true" broadband filter, but it is another option.
Hope this helps!
Zak
chefjedidiah avatar
Thank you both,
An preference on filter wheel or filter drawer?
Tareq Abdulla avatar
Thank you both,
I have QHY and ZWO filter wheels, i like the one from ZWO but not from QHY because it is an old version [Version 2], and i have many planetary ZWO cameras so i use a filter wheel also with mono cameras.
I have only one filter drawer, from Antlia, it is an amazing design, the only drawback or cons i think about it is the way of locking the insert inside the filter drawer, it is with screws, so if you never change the filter during imaging then this is perfect, but if you decided in the middle of imaging to change the filter then you have to unscrew, this is not good, even if you have multiple inserts you must screw and unscrew to safely lock it, i prefer if it is a knob or magnet type so i can easily unlock to change rather than using Allen/L keys.
Thank you both,
Filter drawer would be my choice, obviously. Just make sure it has magnets and it is from a reputable manufacturer. Get as many sliders as needed.
Brian Puhl avatar
Askar makes a pretty decent little filter drawer that I'm currently using for my color camera.  Comes with all the adapters you'd ever need.  If anything, it's just nice to have the extra adapters.
I'd also give a +1 for the ALP-T filter instead of the L-extreme.    I despised my L-extreme personally, ALP-T data was always much better when it came to the stars.
Joe Linington avatar
Manual filter wheel, much cheaper than a motorized one, usually holds 5 filters so also cheaper than a filter drawer and holders. It also keeps all of the filters dry and clean.
I am under B-5/6 and use an Astronomik L3 UV/IR for narrowband and an IDAS NBZ for narrowband. I am not sure that either would be ideal under much brighter skies.
QHY268C offset value
I'm wondering what offset value other QHY268C owners are using. Thanks
QHY268C owner seeking advice; offset likely discussed in responses.
Jan 22, 2022
Review: ToupTek 36mm LRGB and SHO Filters.
Thought I'd share my thoughts about the ToupTek Astro filters I've been using. Brilliant budget friendly filters. ToupTek Astro 36mm LRGB + SHO Filter Review. Introduction.We all know how expensive astronomy can be. Further to that, we all kn...
ToupTek filter review relevant to filter selection for imaging setup.
Mar 27, 2025
binning, f-ratio, pixel-scale, drizzle, onag vs oag and the consequences for my next imaging setup
Fellow friends of the night sky, Just two months ago, I opened a thread asking for your opinions on which scope to buy. Today, I’m back with a similar goal. I’m willing to invest a significant amount of money to either complement or replace my existi...
Discusses binning and OAG setup considerations for imaging systems.
Dec 15, 2024
Dual Band Filter Discussion
I am looking at getting into nebula imaging more and want to get a good Dual Band filter. I am using 2 different OSC cameras the asi533mc and as asi2600mc duo. I am basically in a bortle 7 I have a ZWO dual band filter but it gets halos on all my sco...
Dual band filter discussion relevant to filter wheel options.
Apr 16, 2025
Astronomik Filter Halo Story
This will be long, TLDR: Myself and at least a few other competent imagers have had recent issues with Astronomik Deep Sky RGB filters and Astronomik's customer service. Buyer beware. I will preface this by stating that I am not looking to bash a...
Filter performance issues and recommendations for deep sky imaging.
Feb 8, 2025
