Pariah avatar
I love this tracker
Background:
I rapidly progressed from a full frame DSLR wide angle on tripod, to an Omegon tracker, to a Skywatcher tracker, to a Fornax tracker and Vixen SXD2 mount
I bought the LT2 after banging my head against a wall in trying to overcome the inherent failings in a Skywatcher Star Adventurer 2.I won't go into details about that here, and I know several users are more than happy with the wobbly little pot metal box of poor tolerance gears and wheels, but I wanted something that would give better than 50% keepers on longer exposures and focal lengths, and wouldn't go out of polar alignment if I sneezed.  Maybe I'm being too harsh. It worked sort of OK at shorter focal lengths and exposures, despite the apparent quality of manufacture.
Better gears than my SWSA
So, my thoughts, impressions, and stream of consciousness ramblings on the LT2:
First up, it isn't cheap. Probably because it's well made and highly accurate. But that comes at a price.  And the associated Fornax wedge is too expensive in my opinion, but it works. All in, for the money I've spent on the rig and accessories, I could have bought a HEQ 5 Pro, and had Go-to, but I travel out into the desert so need a relatively quick and portable set up. Plus my previous Skywatcher experience had put me off the idea of cheap Chinese mounts and tuning.
The LT2 uses a 30 degree sector arm to give the equivalent of a very large diameter drive hub, together with a friction drive wheel and electronic wizardry to track at a claimed 2 arc second PE or better. More on that later. It can rotate through ~ 30 degrees before it reaches the travel limit, which is just less than 2 hours of exposures. It also runs off a 12V supply. These are frequently cited by paid product promoters sorry 'Youtube Astro Influencers' as drawbacks and reasons to place their free samples higher in the rankings, which is incorrect IMO.
The 12V is easy, either run from a 12V supply, an ASIAir or a 10,000 mA battery bank with a USB 5.5 -12V converter like I do (it draws very little current when tracking)
The apparent time limitation on tracking is easily addressed with a panoramic head. As the LT2 approaches the tracking stop, turn it off, release the pano head, reset the sector arm, re-tighten the pano head, check framing, check focus, then start tracking for another 2 hrs. Takes 5 minutes or less
Polar alignment.. well, i went through a few iterations before I got this nailed. I started with a polar scope and collimator adaptor. This worked fine but would take me 20 minutes to set up and dial in each time. I did consider a Polemaster but this required a PC, and I wanted to keep it simple. Plus the name 'Polemaster' sounds a bit like a strip-joint nightclub star, not that there's anything wrong with that I suppose.
I already had an ASI Air Pro but didn't realise that I could use the AAP software PA routine with the 30 degree rotation limit of the LT2. It asks for 60 degrees but guess what, I decided to give it a go one evening and it worked perfectly. Here's how: Set up, level, +/- 5 degrees of north using a compass (the limit of the adjusters in the wedge). With the tracker off, use the main camera for PA using the AAP plate solve process. Switch on, rotate 30 degrees, switch off, complete PA. It's that simple. I can get better than 1 arc minute every time, and because I am using the camera rotational axis rather than the polarscope outrigger, there's no cone error.
I can use the LT2 two ways. For shorter focal length stuff on visible targets, Milky Way etc, get it polar aligned, don't bother with guiding, use a red dot finder, get to work. Rock solid tracking, every frame a keeper unless the conditions change.
Targeting of DSO's at longer focal lengths was a bugbear though. Using a red dot sight, I would star hop, then fish around in the dark taking photos to see if I was on target, then mess around with the RA and Dec adjustment for a while trying to center the target in the frame, and just forget it for dim DSO's, it was like blind darts interspersed with occasional yelling at the sky.
BUT THEN Enlightenment. The ASI plate solve and DSO annotation functions completely transformed my targeting. Get it roughly pointed, plate solve, enter the values in an android spreadsheet, rotate the RA and Dec pan heads the required angles, plate solve and find the target in frame. I now use a worm gear Dec head to allow fine adjustment to center targets. I can be on point in a few minutes.
Counterbalancing. I've seen videos on youtube by Fornax users with the most ridiculous assemblages of ball heads, extension arms, DSLR's and 400mm photo lenses that must weigh 5 kilos mounted precariously above the center spindle. Accident waiting to happen is all I can say. As the mount tracks the center of mass will move away from the pivot and place increasing strain on the drive wheel and motor, resulting in poor guiding, stalling or slippage, and there's always a risk that the moment will 'unwind' the ball head at the mount screw and dump your gear off to one side
I'm a Structural Engineer. Trust me, this isn't a good idea[b]  [/b]
(Image courtesy of internet)
Where was I? Ah yes, counterbalancing. I baulked at the ridiculous pricing of the Fornax counterbalance, and then ended up spending more on alternative arrangements. Such are life's lessons in astrophotography. I now use a Star Aventurer dec head and counterbalance weight on a vixen clamp adaptor with a panohead.  Works fine, need to shim the spacing to make sure the counterweight clears the LT2 controls. I like the worm gear Dec adjuster, I use this for manual dithering.
I would strongly recommend a counterbalance arm if you are mounting anything more than a APS-C camera and short lens. Easier to target, track, balance.
Tripod:
The tracking capabilities of the LT2 are completely wasted if you plonk this on a photo tripod with a center pole. I saw the set up above, which uses a Bosch survey tripod, and thought 'now here's an opportunity to reduce the average spending to date'. I bought the heavy duty version for about 60 pounds.  You need to remove the center adaptor screw and fit a 3/8 x 16 bolt and plate to mount the wedge. It's rock solid. Way better than my Benro. So, what does this get us? Here's an AAP screen shot:
I manually dither using the SWSA2 dec head and the pano head, typically every three to five frames. I find the ASI Air Pro invaluable for PA and platesolving. I love this rig for a portable holiday set up. This is what I am taking on my next trip. 533MC Pro, SY 135mm, guiding / dithering RA axis with AAP, manual dithering Dec axis with SW geared head. I have a IDAS NBZ dual narrowband for Ha/Oiii with 3 minute exposures at f2.8:
Example: Orion, 1 hour, GT71 and D5600 unmodded:
Thanks for sharing. I have the same mount  and no, I didn't consider NOT getting the CW bar arrangement from Fornax, expensive as it seems. I still, however, have to come at an arrangement with how to make fine adjustments in Dec (Alt). Any suggestion there?
P.S.: I'm an structural engineer too.
Tarun Kottary avatar
Can you add more pictures of the setup?  how did you attach the Skywatcher Dec Bracket on to LT2?
No matter how accurate it is , the 2hr re-set is absolutely annoying. I now use single arm astrotrac360 which is equally good and I don't have to keep myself awake to reset every 2hours.
Pariah avatar
I use a pano head with degree scales on RA, and a SW SA counterbalance arm with a geared Dec head as below:
Pariah avatar
Tarun Kottary:
See above, hopefully its clear
I can live with the 2 hrs. I use it mainly as a travel rig for either wide angle Milky Way (so 2 hrs is not an issue) or longer DSO tracking. I manually dither so babysit the mount anyway. When I rewind the sector arm about RA axis, I check focus and platesolve. It's easy to reframe targets using the degree scale on the pano head and platesolving
I liked the look of the astrotrac 360 but it seems to have been a 1 man operation and support seems to have disappeared. Great bit of kit though!
Pariah avatar
I also use a Vixen counterweight arm for wide angle Milky Way stuff. I would replace the SY135 with a D610 and 20mm f1.8 lens
Food for thought, thank you! I checked few prices online and the cheapest I get for a pano head and a geared pano head is over 120 quid plus shipping. If I can get away with the geared one than is about 80 quid cheaper. Would you think doing away with the geared head on Dec viable (considering a 300mm lens at most)?
Brian Fulda avatar
With the recent influx of harmonic drive mounts, the Fornax LT2 just doesn't seem like a logical purchase at this point. In 2016, or even 2020, sure. But now? I don't think it's worth it. I also looked into it extensively as a portable option, but here are some reasons I didn't buy it:
  • It can only track for 107 minutes at a time
  • No GoTo capability
  • It weighs 15 lbs (7kg) fully assembled with the wedge and counterweight bar
  • It can carry up to 26 lbs (12kg)
  • All of the above costs over $2000 USD, then you have to add the cost of a capable tripod ($300) and a ballhead ($25), so all in, you're looking at like $2400 USD
The new ZWO AM3, on the other hand:
  • No tracking length limit
  • Has GoTo
  • The head weighs just 8.5 lbs (3.9 kg), no need for counterweights
  • It can carry 17.5 lbs (8 kg) without counterweights, more than enough for DSLR/widefield imaging. If you need more, you can add counterweights.
  • Costs $1800 USD total WITH the tripod and everything you need to get started.
There are other mounts like the new iOptron HEM15 that have similar performance and weigh even less. I hate to say it, but unless Fornax drop their pricing dramatically, it just doesn't seem like a viable option in 2023. Harmonic drive mounts are superior in basically every way, including price now.
Brian Fulda:
  • Has GoTo
Very US-centric view. From were I stand the LTII is still cheaper, smaller, lighter and can be mounted on a standard photo-tripod. And I don't need the counterweight bar for anything but the heavier loads.
Brian Fulda avatar
Brian Fulda:
  • Has GoTo
Very EU-centric view  The LT2 is slightly less expensive on Teleskop Service at €1440 total vs €1679 for the AM3, with neither price including the tripod.
So yeah, it is less expensive, but not by a whole lot, especially considering the benefits you get with the AM3 or iOptron HEM15, which is basically the same weight as the LT2 without the counterweight bar and can carry much higher of a payload.
Oh and you can use some standard photo tripods with the AM3. It has a 3/8" thread on the bottom. So, no, still not really a "US-centric view."
Pariah avatar
Brian Fulda:
  • Has GoTo
Can't argue there Brian. There are go-to alternatives out there and as I noted, the Fornax is expensive, maybe because it's not made in China by cheap labour and appears to have good QA and QC.
However, I would comment as follows in respect of some of your points:
Firstly you are not comparing apples with apples. The Fornax is a tracker, not an EQ mount
When used as a tracker (its primary use) without guiding, or counterweight, it weighs in at 1.2 kg and costs Euro 450 ex taxes
It guides at around 1 " periodic error, so you don't need to guide, or use a PC or AsiAir.
The accessories are expensive, but you can use a WO wedge instead of the Fornax wedge and a Skywatcher counterweight, as I have.
I have a Vixen SXD2 mount for go-to AP imaging. Nicely made, reliable and Japanese quality. My next EQ mount will probably be a RST 135E.
I'm keeping the Fornax LT2, as a travel tracker it is hard to beat
Clear skies
In my UK-centric view (sadly no longer EU-centric) the body is £559 (but at the time of me buying it it was £450, that's some inflation for you). You can get a SW wedge for £65 and a polar alignment scope (SW) for £35. Add another £35 for ball head and bracket and you have a grand total of £694. The cheapest option of strain-wave mounts is still the HEM15 at £1,299 with iPolar (and there is no other "easy" way to add a polar alignment scope other than using an iPolar), that nearly 90% more than the LT2, never mind the latter is smaller and lighter too.
Besides, as the OP posted above, it is really an oranges and apples comparison, as the LT2 is a tracker not an EQ mount. If I want one I'd get my Vixen GP with OnStep controller and be done with it.
Brian Fulda avatar
Star trackers are technically equatorial mounts, just miniaturized and not as full featured. But hey, to each their own. If it’s working for you all, then keep at it.
Arun H avatar
I own a Fornax Lightrack II and have used it for years. Its main virtue is its portability - I have frequently taken it in airline carryon.
I certainly think of it as a wide angle, relatively short total exposure time mount versus being suitable for more serious work.
Yes, it has low periodic error, but the fact that you are mounting it on a camera tripod, using a ball head and the general flex in the whole setup are far more significant limitations. That plus the fact that the apparent motion of stars is dependent on the altitude. I have used it up to 400mm focal length, but at those f/ls, the whole set up  is highly sensitive to wind and vibration. The wedge has smooth azimuth adjustments, but the altitude adjustments are much more problematic and stiff. Yes, you can use a panoramic head, but good ones are even more expensive than the tracker itself.
I don't mean to be overly negative about it - just to make people aware of its limitations. Used within, it can certainly generate good images. But there is a reason most of us move on to proper mounts.
GTom avatar
*I have seen reasonable results with just a plain gimbal head directly installed on the LTII, carrying a 2.8/300 telephoto. Dithering is a pain though.
Gimbal and ball head setups are self-balancing.
Simone Scarpa avatar
I know this topic is old but here are my 2 cents after acquiring the mount.
I think if you have to be guiding, you are better off even with a portable german EQ mount such as the Star Adventurer GTI which is pretty neat for portability considering it only needs 8xAAs. It will be sturdier and cause you less pain and you will have less fear of messing everything up with a bump. As others pointed out, there are harmonic drive mounts now which perform very well…but all need guiding due to their periodic error (except for very expensive high-res encoder units).
The Fornax for me shines in its unguided accuracy. As long as your setup is light enough, not introducing flexture and limiting vibrations, this portable unit has no competition even in 2026. 2 weeks ago I took it out for a spin and easily managed 5-minute exposures at 300mm (4.5 arc-sec per pixel) with 100% keep rate; as long as alignment is done properly. Heavier setups are theoretically possible, taking advantage of this performance, but any 80mm scope is where I think I draw the line (2-3kg for a fully accessoried OTA + the limited stability take a toll, even if the tracker can support the weight). The 107-minute rewind is easy in theory but then the lack of motorization for framing and dithering makes it a bit painful at long focal lengths.
I think the Fornax sits in a place between a big setup and a “portable widefield DSO setup” for the people who are let down by the poor quality control of some worm-gear small trackers on the market such as the Star Adventurer, but still want portability. If I wanted to stick with 35mm of focal length I’d just use a Move Shoot Move Nomad as I think the “bigger” trackers should manage at least a good performance at 250mm, given they are marketed as an upgrade to their “mini” versions, but they don’t. Tiny trackers (SkyTracker Pro) perform well enough even at 135mm sometimes, with 90-seconds exposures achievable. I think iOptron has better QC but I have no experience. This small rant at the end is just to say that I was one of those users frustrated by the garbage performance of the Star Adventurer. The only thing Sky-Watcher did that was good is the counterweight system which is perfect for the Fornax.
Well Written Helpful Insightful Respectful Engaging
HEQ-5 - Last update of Synscan and Polaris Position wrong
Hello everyone, I started astrophotography recently on my HEQ-5 and while it was making more and more sense, I'm at complete loss now. To start with, here's a bit of my situation: many of my pictures were showing motion of stars, making the p...
Tracker alternative to mount for sharper wide-angle astrophotography images.
Oct 30, 2021
Tripod you use with your SGP
Hi fellow SGP images, I’m currently using an Amazon bought tripod which is very light and portable but not hugely stable. Wondering what you folks are using?
Reviews tracker equipment for portable astrophotography setups and stability improvements.
Aug 1, 2021
Planetary lucky imaging frame analyser
Hi all, I was thinking which is the most efficient way of analysing the quality (seeing) of an AVI file while out in the field? I know autostakkert can run frame analysis for each video sequence but is it a case of just manually viewing the seeing in...
Tracker reviews may help with equipment setup but don't address video quality analysis.
Nov 19, 2021
How To Setup The Seastar With Skywatcher Wedge For EQ Mode
Hello and welcome, I'd like to ask questions and reach out to anyone using the Seastar with the Skywatcher Staradventurer Wedge to set up the Seastar Into Polar aligned when using it in EQ Mode. I know I asked something relevant before, but I wan...
Author experienced Skywatcher Star Adventurer issues; may find Seastar wedge setup helpful.
May 31, 2025
Is a Sony FE 70-200mm F2.8 or Tamron equivalent lens good as a starter lens for DSO astrophotography?
Hi everyone, I'm an newbie interested in astrophotography, but also day-time photography. I've just bought a Sony A7iv (full-frame mirrorless) camera for both and have a Sony FE G 50mm F2.5 lens. I'm currently shooting untracked to get ex...
Tracker review relevant to untracked progression and future equipment planning.
Jan 23, 2022
