Which mono camera to go from after the vTEC 533c camera?
5 replies357 views
Matija Jakičević avatar
Hello everyone,
I have a question about going from osc to mono, which camera should I go to? I've been using the Omegon veTEC 533c camera for a bit and had gotten quite used to the 533 sensor. That's why I've been thinking of going the mono 533 route such as the asi or ares-m even.
My scope is a 250pds (254/1200), with good average seeing at around 1.3". I thought about going the asi185mm way as I have quite a few nights with even better seeing, but I didn't quite like the oldness of the sensor as well as its low full well capacity.
What do you guys think I should do?
Thank you for your time and clear skies!
Respectful
Nick Grundy avatar
I assume price is a factor? The 250pds should cover an APS-C size sensor. Is the ASI2600MM an option?
Nick Grundy:
Ah right yeah, that's a bit too expensive for me. Up to 2000 euro I'd be willing. :c
The RisingCam (ToupTek/Altair) IMX571-based cameras should fit the bill (literally).
Brian Puhl avatar
+1 on the Touptek or risingcam IMX 571. They're right in the price range.
Tareq Abdulla avatar
I have two Touptek IMX571 cameras, one in color one is mono, each is cheap enough than other known brands.
3" Focuser Support for Orion 8" Reflector
Hi folks, So I've been recently looking to finally upgrade my camera train. I've been looking at the 6200mm / Zeus-M cameras, but learned that going to such a size would require a 3" focuser to ensure I don't have vignetting issues&#...
Discusses camera selection for telescope setup; relevant to mono camera choice.
Jun 3, 2025
Planetary Imaging Setup and Prep
Finally finding some time to get back to imaging and have been focusing on getting my planetary routine set. I've ran into some frustrating challenges along the way and wanted to see how others have overcome these things and maybe learn something...
Directly addresses planetary imaging setup and camera considerations for imaging.
Apr 24, 2025
Dual imaging with identical cameras.
Hello everyone, thanks for letting me join the group. To make the most of our challenging weather, I'm trying to put together a dual imaging rig for narrow band. This will be an FLT91 and Zenithstar 73 mounted together on my CEM60EC. I've alr...
Discusses mono camera selection; author considering second camera for dual imaging setup.
Jan 19, 2022
