Ha areas of the Tarantula Nebula are not red... why?
11 replies698 views
George Hatfield avatar
I recently processed (RGB) data from this nebula (https://www.astrobin.com/coo844/), and in spite of my efforts with color calibration using SPCC in Pixinsight, the nebula has a definite blue cast rather than the expected red of such a strong Ha area.  I've looked at other images on AstroBin, and many that show red in this nebula have incorporated Ha, which explains why the nebula is now red.  My question is, why doesn't the red show in RGB images that are not supplemented with Ha?   And are there any special techniques to bring out the red in an RGB image?  Note that the Ha areas of the nebula on the left side of the image are red.
The simple answer is that the Tarantula isn't mostly Ha, but a mixture with a lot of OIII and Hbeta emissions together with Ha, but your color calibration seems quite off even with that in mind. The image below is a pure RGB with equal exposures in all channels:
Helpful Insightful Concise
Thanks for the advice.  I went back and ran the linear fit again for R, G, and B (against R).  Then created, the RGB and, eventually, the LRGB.  SPCC seemed to work fine, but it removed most of the red from the Tarantula.  I then tried ColorCalibration… same but to a lesser degree.  So I think I will forgo color calibration and see what I end up with.  Thanks again.
George Hatfield:
Thanks for the advice.  I went back and ran the linear fit again for R, G, and B (against R).  Then created, the RGB and, eventually, the LRGB.  SPCC seemed to work fine, but it removed most of the red from the Tarantula.  I then tried ColorCalibration... same but to a lesser degree.  So I think I will forgo color calibration and see what I end up with.  Thanks again.
Did you CC at the RGB stage or at the LRGB, can't understand which.
I ran SPCC (after solving) on the linear RGB.  Then on to LRGB.
RGB
Noise X
IS
SPCC
etc
George Hatfield:
RGB
Noise X
IS
SPCC
etc
Seems in the right order other than running SPCC (use CC instead). I don't get what IS is...
IS is the script ImageSolver which is needed to re-plate solve the image for SPCC since the R, G and B were cropped early in processing.
George Hatfield:
OK, got it.
Tim Hawkes avatar
The concensus of astrobin images is probably a poor guide to setting the 'right'  colour balance of an RGB image since many images are NB, have NB  mixed in and in any case have colours adjusted for maximum drama and contrast
I suspect that SPCC gets it right and that having the red look more prominent  is more fashion than reality?
Tim
Tim…  I agree.  In my experience, SPCC does a good job.  I just wanted more red without adding Ha.  If you look at the other Ha areas in this image, they are very red with SPCC calibration (image 1).
Tim Hawkes avatar
George Hatfield:
Tim...  I agree.  In my experience, SPCC does a good job.  I just wanted more red without adding Ha.  If you look at the other Ha areas in this image, they are very red with SPCC calibration (image 1)
Indeed. I like your image but I think that the first is the better in fact.  There must be shed loads of blue light - from all those newly formed stars as well as some reflection nebulosity as well as OIII which - as in planetary and some Wolf Rayet nebula - starts to dominate where stars are hotter and the electron temperature up above 40K and more.
Wei-Hao Wang avatar
Like Andrea said, the nebula has strong OIII and Hb emission.  So no matter how you do the color calibration, as long as the calibration is sort of correct, you won't get very red nebulas.  The same goes for many other nebulas in LMC and SMC.  This is basically a consequence of less dust absorption in LMC and SMC, compared to Milky Way.  If you want red nebulas, you will have to either add Ha, or shift the overall color balance to red, or rely on special techniques to enhance the red in the nebulas without affecting the overall color balance.
Johnson-Cousins BVR Flat-Top Filters vs RGB Filters
Hi all, I have recently been deliberating on filter choices for a new system I am putting together (it's a PlaneWave CDK20 that will be installed at Obstech). The system will predominantly be used for deep sky imaging. I was originally thinking a...
Discusses RGB filter characteristics relevant to color reproduction issues.
May 17, 2025
[RCC] Jellyfish SHO +RGB Stars
Hello everyone, I would like to present my image of the Jellyfish Nebula here. https://app.astrobin.com/i/spubzv I always try to present the narrowband images as naturally as possible. The color contrast is not too high, but the different areas of Si...
Demonstrates combining narrowband Ha with RGB for red nebula imaging.
Apr 4, 2025
Review: ToupTek 36mm LRGB and SHO Filters.
Thought I'd share my thoughts about the ToupTek Astro filters I've been using. Brilliant budget friendly filters. ToupTek Astro 36mm LRGB + SHO Filter Review. Introduction.We all know how expensive astronomy can be. Further to that, we all kn...
Reviews LRGB and SHO filters affecting nebula color capture.
Mar 27, 2025
