horrible guiding with ZWO OAG-L and ASI120MM
12 replies632 views
Christian Bennich avatar
Hey
I am setting up my new camera with the ZWO OAG-L as well.
Previously I was auto-guiding with the ZWO 30mm guide scope and the ASI120MM.
Today I switched to my new camera, which has perfect focus. But my guiding is now horrible.
I have what I believe is a good focus with the guide camera.
What should be a good set of standard settings to start with when auto-guiding with the OAG-L.
are there any good videos or descriptions of how to configure for OAG guiding??
It's both my RA and DEC that's fubar.
I have rebalanced my scope, recalibrated the guider in the ASIAIR app etc.
I have during the night tried different settings with the guide system on the ASIAIR.
Currently I have the following:
Calbration step: 8000
Max DEC: 2500
DEC Aggr: 50%
Max RA: 2500
RA Aggr: 50%
Exposure - tested both short and longer - up to 5 seconds
I image with the Skywatcher 200 PDS, ASI2600MM and the EFW (36mm) as well and I have 55mm backfocus as described in the documentation.
The OAG is placed in front of the filterwheel as described here: https://astronomy-imaging-camera.com/wp-content/uploads/APS-C冷冻相机加OAGL连接方案-英文.jpg
Any help, input etc. on how
Rob avatar
Do you focus the guiding camera in the guiding screen or do you switch the guide camera over as your main camera in the ASIAIR to focus it?
I have the same camera with my OAG (not the L one) and it's sensor is so tiny that I have a very small FOV to get any stars from.  I always focus the guide camera as the 'main' camera in ASIAIR.  I bought the helical focuser for it to make it easier.    Make sure you changed the focal length in the ASIAIR settings for your guide camera to match your main camera.  If you focus it like I do as "main" you can plate solve the image and get the actual focal length to use for the guiding menu.
Rob:
Ahhh, good points. Thx.
Will test at next clear night.
Stefan Pfleger avatar
Christian Bennich:
Hey
Max DEC: 2500
DEC Aggr: 50%
Max RA: 2500
RA Aggr: 50%
Could we see a guide log? With the OAG your pixel scale will have improved a lot. It could have been that you had issues in your mount all along which the old guide scope didn't really pick up on. This happened to me anyway, upon upgrading to a bigger guide scope I had to readjust the agression settings and I also had to work on my backlash.
Helpful Insightful Respectful
Michele Campini avatar
I'had the same setup, but i used ASI174mm mini instead of ASI120mm mini. No problem, guide was perfect.
Steven avatar
Only thing I can think of is the 120MM being an "issue"
It's a lovely camera, but you might be pushing it for an OAG, especially through the 200PDS.
it's easy to get enough stars for guiding with a 30mm guidescope. But your field of view with an OAG becomes ALOT smaller, maybe too small for the small sensor.
Are you sure you're getting enough stars for the ASIAIR to use? Perhaps upping the gain and sensitivity might get you more stars and more things to work with for your ASIAIR. Hope that helps
Otherwise, you may need to upgrade to a 290/220/174
Any screenshots could perhaps help. Best of luck!
Great input @Steven de Vet - Bad weather is coming in here in DK the next week + some business travel. I will update the thread when I have some clear skies again.
Stefan Pfleger:
Christian Bennich:
Hey
Max DEC: 2500
DEC Aggr: 50%
Max RA: 2500
RA Aggr: 50%
Great input @Stefan Pfleger - Bad weather is coming in here in DK the next week + some business travel. I will update the thread when I have some clear skies again.
I had not set the focal length correctly for the guidescope after switching to the OAG.
Here's the guidelog from yesterday.  PHD2_GuideLog_2023-06-16_235105.txt
I did try multiple different aggression settings, guide speed, exposure etc. during yesterdays session - nothing seemed to help or make it any better. So the guider ran with above settings for an hour - just to produce some "first light" data for my new ASI2600 camera.
Ive done that before, so essentially you would have massively overcorrected everyime. with the correct focal length, you should be perfectly fine i reckon. Best of luck in your future sessions.
Okay, so Ive just had a look at your guide log.
I have also noticed that you tried different calibration steps. I reckon you have figured the correct step size there but Id stick to 1000ms, not the 8000 you mentioned above here in the thread. But yes, I think it will be fixed once you update your focal length.
Thx, the 8000 did work well with the smaller guide scope. The first Guide Calibration I did was crazy with such big steps - it was all over the place smile
Will drop to 1000ms for sure.
Dustin Gazz avatar
I'll add that the 220 is an incredible guide camera for OAG. I have never had to rotate to find a guide star since I started using it, and I use the standard ZWO OAG with the smaller prism shooting F7 and F10. Maybe it's luck, but it has always found a star so far.
Well Written Concise
OOOHHHH YEAAAAHHH 🤪🤪
By sheer luck - it cleared up tonight......This is what I hoped for.
Rob avatar
Good to see it's working!  Clear skies!
Struggling to guide my Star Adventurer GTi
Hello the setup i have used is - Star adventurer GTI - asiair mini - Svbony 165 and - Asi 120mm Mini but i had lot of issue during my first guide night my polar alignment was that: https://i.imgur.com/pDnzSNA.png but still lot of issue with the calib...
Similar guiding issues with ASI120MM; troubleshooting approach may apply.
May 3, 2025
AM5 Simultaneous Guiding Spikes
My last two sessions with my (new to me…) AM5 haven't gone as I'd like. I mostly image with an NP101 and use a 120MM Mini hooked to a WO 32mm Uniguded (120mm FL). I used to have the following defaults: Guide rate = 0.5X Guide exposure =...
Guiding spikes problem; OAG configuration and PHD2 settings relevant.
May 27, 2025
Struggling to guide my Star Adventurer GTi with PHD2
Hello, I first got into astrophotography two years ago and quickly began accumulating gear slowly but surely as the months went by. I recently acquired a guide scope and a guide camera to improve my exposure times, which were previously limited to ~4...
PHD2 guiding setup struggles; OAG-L configuration guidance applicable.
Apr 25, 2025
PHD2 Settings
I've spent multiple nights trying to set up PHD2 guiding with my mount but keep encountering high backlash (>4500ms), which, based on my reading, is quite excessive.Tests Conducted: Sidereal rate settings: Test 1: 0.5x on both RA and DECTest 2...
PHD2 configuration challenges; autoguiding settings optimization directly relevant.
Mar 10, 2025
