Weird trails when stacking comet + stars on DSS
5 replies296 views
Guillermo Moreno avatar
Hello everyone, I've been having some trouble stacking my ZTF image on DSS using the comet+star stacking. As soon as I start stretching the image on photshop trails start to show up all over the image (looks like they are the shadow of the stars on every image). I've tried changing most of the settings but to no avail.
Has anyone encountered this issue before? Is there anything I can do? This is my first comet image and I´m having a hard time getting it right.
I can provide the TIFF image if anyone wants to give it a try.
Thank you very much! CS
Rob avatar
I comet aligned all my subs, then removed the stars before stacking them.  I still ended up with this artifact of trailing 'shadows' left behind after star removal.  This was my first attempt at imaging a comet.  You can see I tried clone/heal in some places.  I ended up just darkening this image to hide it before adding stars back.
If you want to avoid this effect entirely you'd need to remove the stars from each of the frames which have been comet-aligned before stacking them together. You can then add the stars back from either one frame or from the star-aligned stack.
Well Written Concise
Rob avatar
* This is what I did and achieved the image above your comment * 😅
Then the star removal process left artifacts and/or the rejection algorithm wasn't set up properly.
Tim Hawkes avatar
This last comet was indeed a particularly tricky one to get right - at least in my hands- because it was moving so fast.  In my F4 , f 1200 mm system I tried stacking lots of 5s frames so that this movement should blur the comet as little as possible and the centre for stacking be best defined.
However the comet-stacked images then looked like this.. i.e. stacked based on the comet's bright core
When I then used RC StarExterminator on this integrated comet-aligned stacked image - the same as in your case - star removal didn't work completely and trails were left.  I think that this is because  - at 5s - the star images are too close together and not resolved so they are not consistently recognised as stars by the Xterminatoe program.
My particular solution was to go up to 20 and 40s subs which produced linear arrays of more discretely separated stars rather  than the  almost continuous lines  obtained at 5s .   StarExterminator was then able to remove  these better defined arrays much more cleanly.
The price paid was that the exposure time was a little longer than ideal and therefore the comet stacking wsa based upon a slightly oblate brightest centre point.  But the image at the end was passable -and looked quite good after the stars were added back in  (i.e extracted from the star-based stack  aligned to the first image of the comet -aligned stack) . Overall  this method worked and I think a bit easier +faster to carry out than running a star removal on each frame individually before stacking.
I haven't tried running RC StarExterminator  on all 180 x 5s frames individually and then trying comet stacking  - theoretically it could produce a sharper less movement-affected image but it would be a lot of work.  I also suspect that the low SNR of necessarily short individual frames might create problems with artifacts in star removal -- and that this itself may be a problem if that is your procedure?
I realize that this doesn't  really help you with processing your current data set since the solution for me was to change data acquisition exposure times  but  you are not the only one I am sure to have encountered a) difficulty in removing star 'remnants' from the comet-based stack of images and also b) the converse,  to cleanly excise just stars without any residual  spread out comet signal  from the star-stack that you add back to the comet stack (this is perhaps a problem with the first image in this thread?).
Incidentally-- one  easy fix for b) is of course is to simply image the stellar background just after the comet has moved on and out of the initial field.
Helpful Insightful Engaging
Comet processing
Hello! I'm looking for advice or suggestions please. I have reached the same old wall in comet processing. I get to where I think I should be, which is: I get an image aligned on the comet, and I get a star aligned image on the stars. But when I ...
Directly addresses comet+star stacking trails issue on DSS software.
Dec 12, 2021
Help with a just discovered photo of the A3 Atlas
Hello there guys, how are you doing? As the title suggest, I just discovered, almost by accident, that last year, after trying to capture the comet without any luck, that one of the days I left my camera doing a timelapse just to make a comparison I ...
Author discovered comet photo; discusses comet image processing and stacking.
Apr 24, 2025
Cosmic Clarity Satellite Removal Tool
Satellite trails are becoming more and more of a problem in our sub exposures. Don't throw out the exposure because of satellite trails, remove the trails from the image!! I am sure everyone here has examples of a satellite trail making its way t...
Addresses artifact removal from images; relevant to trail/shadow removal problem.
Nov 23, 2024
