Hi all,
Returning to the hobby after a couple of years out and of course I've forgotten everything I learnt about PI. I see that WBPP has come on since I last used it. My question relates when SubFrame Selector should be used in the Processing Workflow. I've read where some use it after Blink but before WBPP and others use it after debayering in WBPP the continue once they have removed the bad subs.
1) So what is the correct/preferred way.
2) If you use SFS after debayering how do you pick up the WBPP process part way through (i.e. from registration). I tried by unchecking the processes in the Pipeline but it just went back to Calibrating.
Cheers in advance for any help.
Rene
Rene
