[RCC] Carina Nebula
5 replies179 views
nerdybeardo avatar
Hi All... I'm looking for some tips and critique on my Carina Nebula.  It is my favorite image so far that I've processed but wanted to get your views on where I can make some improvements.  This is the only image that I've taken from a remote telescope site so the data is really good given the location and equipment that were used.  I'm looking for some feedback on my processing techniques, what do you guys think and where can I improve?  Thanks in advance!
https://www.astrobin.com/full/vn32g4/C/?real=&mod=
Marc Agostini avatar
I actually stumbled across this when I was researching ideal subexposure length for telescope.live and it instantly caught my eye! Really well done, It really has a great depth to it, my only minor critique would be that the sharpening in the high contrast areas (for example the V-shaped dust lane in the middle) is a bit too much for my taste, to the point where some of the details turn to artifacts. Maybe a bit less is more here. But that's also dependent on the scale you're viewing it; If you're not pixel peeping at high magnification, this gives a great overall impression of sharpness. And also the sharpening in the bright parts works perfectly!
nerdybeardo avatar
Thank you Marc for the awesome feedback!  I will look to see if I can improve the sharpening in those areas!
Bogdan Borz avatar
Hi Nerdy,
I already saw your image before (I liked it btw : ) ). Few things you could improve (I have no idea how the subs or the initial master looks like so it's difficult to judge). The background is too black. You probably clipped some data, the blending could be smoother. The key hole area looks probably overstretched (curves probably). Some stars are burned. So I would say you have to be less aggressive with your histogram stretch or initial NL stretch. Smoother masks probably, take the time to make a good star mask. I like the palette. I think your data probably has more potential. The dark nebulae in the Carina are too dark/black. Play with the cursor and see when you lose signal, and don't go there : ). My two cents.
Bogdan
nerdybeardo avatar
Thank you Bogdan!  Really appreciate the input!
urmymuse avatar
Loads better than my version also taken from a hosting facility … I only captured ha and Oiii though and made synthetic green channel. I may have a go at reprocessing based on what I have read here.
M51 - how to acquire or process the red nebulosity ? Are HA pictures useful for galaxies ?
Hi All, So thanks to learning in this forum, I improved my image processing game (PixInsight) a lot and finally got an image I’m partially satisfied with https://www.astrobin.com/full/bwmj3z/0/?real=&mod= I see is most really good M51 pictures th...
Processing techniques and feedback on nebula image improvement.
Jun 12, 2021
Using Deconvolution in Pixinsight
Hi Folks, My website, Cosgrove's Cosmos, has just published some new posts under its Tips & Techniques Section entitled: "Using Deconvolution In Pixinsight". https://cosgrovescosmos.com/tips-n-techniques/using-deconvolutioninpixinsi...
PixInsight deconvolution tips for enhancing nebula image quality.
Mar 28, 2022
Request for technical and artistic critic on my images
First off, this community has been so good to me, so I want to thank you all for your time and generosity in advance. I've been doing astrophotography for about 1 and 1/2 year first with a DLSR and for the past 2 months with a cooled mono camera ...
Request for technical and artistic critique on astrophotography images.
Feb 2, 2022
[RCC] DSO processing workflow - am I going in the right direction? (here M42)
Hi everyone, I am quite new to AP and I've been trying to improve my processing technique. Q1: Does anyone of you have some feedback to share with me? like, about the overall look or specific aspect I should take care of?Q2: I've tried to fol...
DSO processing workflow feedback relevant to nebula processing.
Jun 10, 2021
(RCC) Tips for sharpening, noise reduction, color balancing etc
Hello! Any idea how I could improve this image? I feel like I may be missing something… Maybe could be sharpened more or less? Better noise reduction? I struggled to sharpen the dark structures… If anyone wants to play with the data I cou...
Tips for sharpening, noise reduction, color balancing in images.
Jan 29, 2022
