Corrector/Reducer for classical Cassegrain telescope
3 replies224 views
Konrad Krebs avatar
Hi everyone,
I got a very good mirror set for a classical cassegrain relatively cheap. I wanted to tackle this as my next project and build the telescope around it myself.
Now the question is, if anyone knows if there is a corrector or reducer specifically for classic Cassegrain telescopes? Unfortunately I can't find anything.
I have read before that a corrector for Newtonian telescopes should also work. Is this the case?
Since I primarily do astrophotography, I wonder if it is worth building the telescope if I don't have a corrector afterwards and the stars and the image are not good.
Clear skies,
Konrad
What focal ratio is it going to be? That's the key question, specifically I'd like to know wthat are the focal ratios of the primary and secondary to give an idea of what field aberration you'll likely to be facing. And the size of the image plane you're planning to image with.
Konrad Krebs avatar
Thanks for the reply,
the primary mirror has a focal ration of f4, the focal ration of the complete system will be f12. It has a diameter of 200mm, so focal length of 2400mm.
My goal is to use a APS-C sized sensor, so I guess image plane at least something like 28mm?
Konrad Krebs:
So the secondary magnification should be 3 as well as the FR. This gives a nearly diffraction limited field at r=14mm. Unfortunately it has a rather strong field curvature therefore you'd need a field flattener to take advantage of that. To get more details I'd need much more info on the optical layout that you gave me. I'd tend to use a field flattener designed for RCs.
Helpful Insightful Concise
Gear advice
Hello, Please feel free to let me know if this topic is in the wrong area… but I have the 9.25" EdgeHD. I have been using it for a few months now, primarily for visual work and just learning the scope and mount. In the time that I have had...
EdgeHD is a Cassegrain variant; discusses correctors and astrophotography setup.
Dec 16, 2024
Welcome to the Group
Welcome to the newly formed GAS Astrophotography Interest Group GAS - AIG This group will allow GAS - AIG members to post questions and images relating to AIG meetings. This group is moderated and only members of the group can read and post entries.
Cassegrain telescope project relevant to astrophotography equipment and imaging setup.
Oct 16, 2021
[RCC] My First Imaging Attempt with GSO RC 8” Carbon
https://astrob.in/m3c60w/0/ This journey has been both challenging and rewarding, as I worked to perfect the optics and fine-tune the acquisition process, it started with the bane of RC telescopes: the dreaded collimation! The first major upgrade I m...
Documents building and optimizing RC telescope optics for astrophotography imaging.
Jan 30, 2025
