UV/IR Cut filters with RC telescopes
Gso 8 RC Telescope Images 2 replies119 views
Matthew Proulx avatar
I was reading somewhere that a UV/IR filter is not required for a pure reflector system, could someone shed some light on this for me? Thankyou.
Well written Engaging
Michael Timm avatar
Yes, that is true for all reflector scopes. But if you want to put any sort of lense (like a reducer or something else) into the pathway of the light, i would recommend an IR/UV-cut filter.
Gustav Lundby avatar
Might it be that a flattener does not bend the light that much and therefore could be used without UV/IR cut filter?
Also, I see from specifications that the mirrors really do not reflect much at lower NIR wavelengths.
What IR-Pass Filter Do You Use, 685nm or 742nm?
Hello all you lunar imaging GURU’s! I have seen some of the incredible lunar images here on AB and obviously with excellent processing techniques there seems to be on thing in common. IR Pass filters to be specific. In doing some reading on what filt...
Discusses IR-pass filters relevant to reflector telescope optical systems.
Jul 1, 2021
Narrowband filters for fast optics
RASA telescopes, Hyperstar systems and other fast optics is growing quickly in popularity among astro photographers. However popular, these systems requires costly, special narrowband filters with shifted band-pass, and finding good such filters is n...
Addresses filter selection for optical systems, potentially covering reflector considerations.
Jun 18, 2021
