Strange vertical line in image stack
6 replies383 views
Konrad Krebs avatar
Hi guys,
I noticed something strange on a stack, do any of you have any idea what the problem could be?
This is a stack, about 4h, taken with an unmodified Nikon Z6 + Samyang 135 f2 on a startracker. I use this combination more often, but I have never noticed this strange line. I just did an (automated) background extraction, nothing else. I also can notice this line in a single exposure:
Same for this, only ABE.
Any ideas on this?
Konrad Krebs avatar
No idea on this strange line in the image?
To be honest I think it has more to do with the way you stacked up the lights and whether you applied LN to the right frame of reference. From the single light the dark vertical line isn't that obvious…
I have faint memories of something of that sort happening to me once but as much as I rack my brains I cannot recall what was. It must have happened long time ago.
Konrad Krebs avatar
Thanks Andrea for the reply.
I will give it a new try and restack the images without LN. I just used WBPP script as usual.
As mentioned, I have used this setup and workflow many times before and never had such a strange line. I used a startracker there is no possibility that some images may have drifted significantly.
Konrad Krebs avatar
So I had the time to do the stacking again without LN, unfortunately with the same result. I think that there might be any problem with the data or sensor of the cam. I will try to find out more and let you know, whenever I will find the rootcause.
wittinobi avatar
hi,
have you test another (maybe shorter) usb cable, or lower usb-speed (if possible)?
...or another sdcard (dont know how you capture)?
best regards
wittinobi
DSS help
I use DSS for calibrating and stacking images, in some images I noticed poor stacking (one corner where the coma is more evident). Any idea how to improve the quality of stacking in DSS? Any special setting?
Addresses stacking artifacts and image quality issues similar to author's concerns.
Sep 9, 2021
Rare pattern stars on samyang 135
Hello. I purchased from second hand this lens a few weeks ago but I have not been able to test it until these days. I'm noticing some very strange patterns in the stars, like a rhombus or teardrop shape. I have previously the same lens but I have...
Strange artifact visible in single exposures and stacks with Samyang lens.
Dec 2, 2024
Strange grid / stains pattern in background
Hello everyone, i get a strange pattern in the background of my final stack. I used a ZWO ASI 183 MC Pro at -20°C, gain 50, 30s per shot, 1800 shots in total. Dithered every few shots, blinked through all images, nothing obvious. Flats, darks and dar...
Similar background pattern issues in stacked astrophotography images.
Apr 7, 2025
Strange Flats for the first time with Lacerta flat box any idea?
Hi all, I would like to share a very strange experience: I processed (pixinsight) two sessions of capture (newton 150F4) on M104 with flats (Lacerta flatbox withFlat wizard from NINA) per session and got a very strange linear ondulated background as ...
Unusual patterns in processed images; troubleshooting imaging artifacts.
Apr 8, 2025
Artifact in the picture but not in the flat frames.
Hi everyone, While taking pictures, I noticed a strange artifact on the subs. Blue circle with a green border. It was also visible after the meridian flip, but it moved from the position in the image compared to the before the flip. I noticed that I ...
Artifact investigation across multiple frames and processing steps.
Dec 28, 2024
