Can't catalog search using Photometric Color Calibration in PixInsight...help?
2 replies•303 views
Photon_Collector avatar
I'm trying to do PCC in PixInsight, however I can't seem to search a catalog for my target, so it fails each time. Anyone have this problem?
You need to execute the ImageSolver script beforehand, most likely:
Francesco Meschia avatar
Also can you share the portion of the process window log with the error message, so we can see what PI is complaining about?
Any Help With Mosaic Processing?
Hello and welcome. I'd like to ask everyone who used or is using Seti astro software if it can be standalone or built into other software. Does anyone have any luck with Seti Astro? I am trying to process the mosaic stacked image that my seastar ...
Unrelated to PCC catalog search issues in PixInsight.
Jan 5, 2025
Alignment fails in WBPP only when using dark files
I'm trying to stack some data acquired with a 6nm Dual narrowband filter on a OSC camera and the data stacks well if I don't use dark frames. However, when I add any darks or master darks, alignment fails. I've been trying to figure this ...
Unrelated; focuses on WBPP alignment with dark frames.
Apr 15, 2025
Help with WBPP "no frames found after calibration"
I'm getting this, and I'm unable to stack these are my lights: (600s lights are named "Venus", but that's incorrect, just something that the ASIair does when you slew from a named target to an empty piece of sky - the name for t...
Unrelated; addresses WBPP frame calibration, not PCC catalog search.
Dec 21, 2024
