Hi everybody,
I’ve been hunting to get a longer focal length telescope (900 - 1250mm) to image smaller targets for quite a while now.
Currently Im 90% sold on getting the TS ONTC - 8” F4.5 Newtonian… But I really like the idea of an 8” RC as well…
I do have an concern regarding the rear cell configuration on the 8in RC specifically to make my final decision.
I know of the collimation issue on this design due to the limited tilting adjustment due to the focuser / image train being directly connected to primary mirror cell. This can be addressed to some extend by installing a tilt adapter between the scope and the focuser if I understand correctly. However, it seems that the problem runs a bit deeper, in that a heavy image train can actually pull on / flex the whole primary cell, throwing off collimation. Has anybody here have more info on this?
As I understand, on the 10in Truss RC design, this has been solved by completely isolating the image train from the primary mirror cell.
I would be hesitant to invest in the 8in RC with this design limitation. The 10in truss with these issues sorted then seems to be the way to go, although for me personally, it might be just too much scope… Fully loaded at around 40pounds its closing in on my mount’s max load capacity (I have an SB MyT) and I dont really trust that I have the seeing conditions to support 1300mm-2000mm imaging regularly in any case.
Would love to hear your thoughts and experiences.
Regards,
Jacques
Regards,
Jacques
