IrishAstro4484 avatar
I routinely struggle to quickly polar align my EQ6 Pro mount quickly and I have used a variety of methods including NINA 3 point and Drift alignment in PhD2.
I should add, I'm in the southern hemisphere and my view of the pole is obscured.
I suspect it's because my initial alignment isn't very good.
I use an inclinometer and compass for setting the initial AZ and altitude.
Any tips/tricks/advise for speeding up the process would be greatly appreciated.
Rob Foster avatar
Hi IrishAstro,
For me it depends on whether I have just set set up rig or if it has already been out and previously polar aligned.  I am not sure any of this applies to you as you’re in the southern hemisphere, and I am not familiar with the SharpCap use below the equator.
if already out and previously polar aligned on another recent night, I go right to SharpCap for polar align and it takes less than a minute To get  excellent alignment.  I have used the NINA  tool and NINA remains my imaging software of choice, but I have strongly prefer SharpCap as being faster and easier tool for polar alignment.  Just be sure to deselect the camera in SharpCap once you are done with polar alignment before using in NINA.
If i had just assembled the telescope rig, I take the time to do quick polar align thru the EQ6R pro reticle first, then go to SharpCap.  Still usually takes not more than 1-2 minutes.
Rob
Star tracking with Star Adventurer 2i
(Star Adventurer 2i) If I use a ball head with my star tracker can I point my camera at any star or object I want (without causing star trails) as long the tracker is properly polar aligned? The other night I polar aligned the tracker based on a YouT...
Polar alignment struggles relevant to tracker performance issues.
Oct 29, 2021
Astrophotography autofocus routines
I'm just about to set up in-sequence autofocussing for the first time (I'm using APT). I just wondered what strategies people use? Autofocus on temperature change Autofocus on filter change Autofocus on a set time or maybe a combination of al...
Covers automated focusing procedures using NINA software similar to APT.
Nov 23, 2021
How best to polar align?
I have had an EQ6R Pro mount for a couple of months now and am starting to learn astrophotography (with a modest degree of success, I think). I have not attempted guiding yet (as I want to learn to walk before starting to run), so I am limiting mysel...
Relevant - directly addresses polar alignment techniques for EQ6 Pro mount
Jun 21, 2021
SkyMemo tracker running slow -- add an ASIair autoguider?
I'm using a Kenko SkyMemo S tracker, Redcat 51, and Sony a7iii as my primary setup. I'm just now building out my setup; portability matters and my budget is limited, but I'm going piece by piece. With this load, for the last few sessions,...
Speeding up Polar Alignment NINA/PhD2 — Relevant; drift alignment directly addresses tracking drift problems.
Nov 7, 2021
Planetary Imaging Setup and Prep
Finally finding some time to get back to imaging and have been focusing on getting my planetary routine set. I've ran into some frustrating challenges along the way and wanted to see how others have overcome these things and maybe learn something...
Not relevant; focuses on planetary imaging setup, not polar alignment.
Apr 24, 2025
