Luminance Filter Under Bright Skies
5 replies134 views
Abdul Thomas Jnr avatar
Hi guy. So I've been driving away from home to darker skies (Bortle 3 and 4) to capture luminance data using the Astronomik L2 Uv/Ir Blocking Filter. I live under Bortle 7 skies. I'm just wondering if I will be able to capture luminance data under Bortle 7 skies or do you only capture luminance under dark skies? I've got about 6/7 hours already of luminance from dark skies and I need another 5-8 hours of luminance to add to my 14 hours Lpro I capture from Bortle 7. I also have some hours of Ha to add to that. Targets M81/82 with Rasa 8 and Zwo 183mc pro. Looking forward to your answers. Thanks
Nate Hall avatar
In my experience, it will be tough to get a good L channel, especially on difficult targets. I just finished an almost 9 hour run on Markarians; R, G, B we’re decent but L was so noisy/gradients that I went with a synthetic L. This is from my front yard in Bortle 5 with 2 street lamps and lots of front porch lights.
It isn't clear if you're using an OSC camera or a monochrome one. Either way, yes you'd be abe to capture luminance data from fairly light pulluted skies. Sure as the sky is blue I did.
*** I'm using the Zwo 183mc pro which is an OSC? So I can catch luminance from Bortle 7?***
Not sure why you're using the terms "luminance". You've got an OSC camera and as such you might only achieve true luminace exposure only in the near-IR, if ever. You're shooting color and as such you're not doing any "luminace" shooting, just color. And yes, you can do that in B7 skies, same as I do.
Sorry I'm not really an expert in astrophotography 😂. I worded it all wrong. I should have just asked if I can use the Astronomik L2 uv/ir blocking filter under bright skies. So will be doing that tonight. Thanks for your help
What is the target faintness limit for city skies?
Good morning, team. I’d like to start a discussion about the faintest objects that can be captured under heavily light-polluted skies, such as those in Bortle 8/9 zones. My primary imaging location is in West London, where the sky brightness ranges f...
Discusses faintest objects capturable under light-polluted skies like author's Bortle 7.
Dec 10, 2024
Bortle 8 galaxies
Since galaxy season is approaching I'm trying to work out the best approach under my light polluted skies shooting OSC. I've had some success using a very broad light pollution filter but the result may as well be monochrome as far as any use...
Directly addresses galaxy imaging strategies under light-polluted skies similar to author's situation.
Feb 2, 2025
This is disheartening: Now officially under Bortle 7 skies.
I built a home observatory 3 years ago on the roof of my garage living just north of Orlando, FL. This area, while nothing like my Bortle 5 night skies with many clear nights when living in California, was Bortle 6 when we moved here and many more cl...
Addresses astrophotography under bright skies and light pollution mitigation strategies.
May 22, 2021
