Guide scope
25 replies514 views
Tareq Abdulla avatar
Hi all,
I want to buy a guide scope that i can use it with ZWO planetary cameras that are not "Mini" version, and i don't like that kind of Helical rear rotating one with camera, i have ZWO 60mm guide scope and i hate it with that feature, and i want smaller size maybe but effective, any recommendations???
Get a small achro refractor with 1.25" R&P focuser if you hate helical focusers so much.
Nick Grundy avatar
1.25" R&P focuser
if you aren't bothered by a heavier guide scope, anything decent doublet with RP focuser will work.
But...you'll find they can add a lot of weight. I, personally, love the helical focuser (provided its a nice one). I have a 60mm Orion guide scope and it works great. (and only weighs about 2.3 lbs)
Concise
Joe Linington avatar
Most guide scopes will work with a standard planetary camera. I have an old Orion SSAG which is in a typical planetary camera format and it will thread on to both my 30mm SVBony mini scope and my ZWO Off Axis Guider. I have heard of people using a ST80 or one of the many 60mm doublets as a guidescope. I guess the big question is how much are you willing to pay. Something like an AT60 with the reducer would be fast enough and double as a widefield rig when you want one.
James (Jim) Poulette avatar
Maybe a little overkill, or too big for your application - but I can't say enough about using a WO Z61 (360mm, f/5.9) as a guider.
I'm currently using the helical focuser with the ZWO OA and I really like it. It's hard to implement with the Mini's, but with the regular cameras it makes it really easy to set up. Good luck ! smile
I have one but it is heavy if i want portable and using a smaller imaging scope than the guiding itself [it is ST80 with dual speed focuser].
Nick Grundy:
1.25" R&P focuser
I am not bothered by heavier guide scope, but i want to have a small one so i can use with a small setup itself, i mean i have ST80 which is 80/400, it is very funny if i will use this with my 60ED [60/360] or even FRA400, and i am thinking about a small mount that can handle up to 6-8kg so i prefer a small guide scope to go with it rather than 60/70mm main scope and 80mm guide scope.
I don't mind the helical focuser, but not the one with that ZWO 70mm, it rotates with the camera attached or even an eyepiece, i hate this, i want helical focuser to rotate in extending way without rotating the attached accessories be it a camera or eyepiece, i don't know if all helical focusers are in same concept or some can rotate individually, some like the normal focusers we use on our main scopes, the cameras or eyepieces don't rotate.
Joe Linington:
Funny thing is that i want to buy a guide scope to be used with my 60mm doublets or FRA400 which is 72mm aperture, so i want smaller than AT60 or 60 doublet, i do have ST80, if i use larger scopes i can think about using my 60ED or FRA400 or even ST80 for that or buy an OAG, but if i buy a small portable mount that can handle 60mm ED and a guide scope then i must use smaller guide scope than the main one anyway, sorry i didn't mention that in my OP, my fault and mistake.
I have two 60mm ED doublets, and FRA400 and ST80 and larger scopes, i am planning about buying maybe two small cheap mounts so i can use those two 60mm separately or a mount that can handle both 60mm ED with one guide scope, but not expensive big mount, i already have AZ-EQ6, so i have two options, buying smaller one for my small scope so i can do it even from my room window upstairs rather than go out in the yard, or buy big heavy mount in future when i can save it then i can place my larger scope and adding my smaller scopes too together, but this expensive big mount will take long time and headache to buy and setup as i don't have observatory or pier, so i think i will go with the first option of portable small cheap mount for now until i can save to afford bigger, and definitely this small mount need less accessories to handle, if the main scope with camera will be nearly 3KG, it means the guide scope with camera shouldn't exceed or reach 1KG anyway.
Actually i have the 60mm ED doublet i will use for imaging, so i wanted a guide scope for that one, i already have QHY Mini Guide Scope with QHY5LIIm camera, but i will use this with my larger scope such as 90mm triplet or even FRA400, but i wanted another one for my FRA400 and 60mm doublets, i can use this doublet for my larger scope, but i will keep it as a main imaging camera because they are connected to old cooled cameras, better not swap between my gear and make things less headache of remove connect here remove connect there.
Because i have many planetary cameras including mono so i wanted to use those rather than buying extra one as a mini version, i am planning to buy OAG for my RC scope which will be in use in future later once i figure out the mount capability for it, but for smaller scopes such as my 60mm ED doublets or FRA400 or even my 8" F/5 Newt and 6" F/4 Newt and 90mm triplets i better think about something else.
My ST80 will be for solar dedicated, and i will use my QHY guide scope+camera for one setup and not swapping it between another setup i use, most likely QHY guide setup will be for my 90mm i believe or Newt, so i want another for either 60mm or FRA400 without using the same one setup between them all, i will leave one setup and another almost untouched, i might even buy two guide scopes so one from 60 and one for FRA400, and why not another for Newts.
All my small guide scopes have non rotating helical focuses. Don't see why you cant get one…
If the issues is the rotating of the camera with focus, and you want small then the SVBony SV-165 30mm will work. The focus action unscrews the objective lens and leaves the camera alone, it has m42 threads to mount most planetary cameras or you can use a 1.25 inch adapter. It has enough focus to focus a planetary camera but you can also use m42 spacers. It has a locking ring on the focus and weighs nothing. I believe the ZWO scope is very similar. Mine has guided my mount down to 0.5 arc seconds and reliably maintains 0.6 all night with 3um pixels on a colour camera.
Rotating the camera would be annoying, you’d have to re-calibrate every time you adjust focus.
All my small guide scopes have non rotating helical focuses. Don't see why you cant get one...
I will get one, i started this topic here asking for which one or a recommendation to one, i late provided more details i should add first post, my fault.
Joe Linington:
Nice, i will have a look on that one, i might buy two, so thank you very much.
Yes, it is annoying, not just for focus but also for the cable connected to the camera being rotating with it, messy, so i thought that all helical focusers are the same, but then i saw some new helical focusers that doesn't rotate with things attached with it, so i could go with it, but i wanted to know about the guide scope itself first regardless which focuser it uses, my QHY mini guide scope is rotating from the front part of the scope and not back, that is nice to have so to leave the camera and cable alone un-rotatable.
Jerry Gerber avatar
I replaced the ZWO mini guide scope with the Skywatcher EVOGuide 50mm (242mm focal length guide scope.  I am really glad I did.  It produces better and brighter stars and makes guiding very reliable.
https://www.skywatcherusa.com/products/evoguide-50-apo-refractor
Jerry Gerber:
A bit pricey, if i buy this then i will use it with a larger scope such as 90mm triplet or 8" Newt, not with 60mm/72mm scopes.
Pariah avatar
I use 178MM with Askar FMA180 guide scope, on my TS CF 90mm APO. It's excellent and has a good helical focuser
Alan Brunelle avatar
Tareq Abdulla:
Joe Linington:
I strongly second Joe's suggestion of the SVBony guide scope.  That locking ring makes for great stability and since you don't need (or necessarily want) perfect focus for guiding, locking that ring makes the scope bombproof.  Understand that the scope is also a doublet, and performs (edit: as well as) (I was rushing to an appt. getting this out.) some of the other scopes from ZWO, etc, for half the price.  I got the 30mm one for under $50, less than half the price of everyone else out there.  It is also constructed better than my 60mm guide scope.  I added a Baader locking focuser on the rear, and also tried the Baader Clicklock for the 1.25 inch camera.  But went back to the other since I essentially have the whole setup locked and never even change the focus when using my portable system.  And you can buy it on Amazon.  It was funny when I saw a very a very similar thread on CN about guide scopes, and someone mentioned just getting a SVBony for 1/2 price and it was a good scope.  But the person asking the question, just kept ignoring the guy.  He was just incapable of understanding that you could get something for a lot cheaper, was a doublet, had great machining, and a nice locking ring.  So if you want to spend more money, get something else.  And buying on Amazon is simple and if you end up not liking it, trivial to return at no cost or hassle.
Alan
DavesView avatar
I have the William Optics 50/200 UniGuide. Good optics and a long base to battle flexure. Loosen the Rotolock just enough to move the camera for fine focus. Also, when you twist the Rotolock, the camera doesn't turn. About $170.
Tareq Abdulla:
Joe Linington:
Just to update with a photo.
You can see the threading on the front of the scope.  Smooth action.  The red focus lock is solid.  The machined tubing used to construct is quite thick and solid.  No sagging possible.  The dovetail is short, stout and very square to the rings.  Zero flexure on this.  On the 30mm scope, like this one, the rings have only one set of screws that just hold the scope snug to the rings.  There is very little tolerance between scope and rings, so no adjustment for aiming.  I learned that this setup is very square to my mount and points close to dead center of the field of view of my telescope's camera.  And all you need is close for guiding.   The camera stays fixed in this guide OTA and I pop the whole thing on and off the mount, throw it in a carrying bag with my cables when transporting my rig and just pop it back onto the mount when ready.  I mount it on the side of my ZWO AM5 with the AM5 dovetail shoe attached to the side of the telescope dovetail plate.  Never need to adjust anything.  They make other sizes, but I believe this 30 mm is a good match for your 60mm or even greater.  The AM5 seems to demand short guiding exposures and I work at 1 second exposures, at well less than unity gain.  The 30 mm seems to do fine.  There are brighter stars on the guider field, but PHD2 seems to choose the fainter ones.  The setup below includes a 21mm spacer that is leftover from my old camera and the camera is attached through the Baader helical focuser, which I never use for focusing, its just a decent holder that I had leftover from another build.  The Baader click lock worked, but was prone to unlocking too easily and therefore allowing a camera rotation and need to possibly refocus.  The spacer I have here is probably larger than needed, if at all.  The focusser at the front has a lot more play left in it, and as you can see, I have the camera buried just about all the way in, which is nice for stability.
I saw that Amazon now is charging $53 buck for the guider now.  They also have a 40 of almost the same design for ~$70, but the guider scope rings are larger and have the three screws for aim adjustment.  I do not like the higher dovetail stand and rings for the 40mm.  Would seem to add more moment forces and chance for flexure.  For me, I am happy to not have to aim at all.  If I needed this scope as a finder scope, I would probably want aiming adjustment.
Alan
Ok, nice, i will see if i will buy Askar as i keep thinking about buying their FMA135mm one so i can use it for imaging too when i want super wide, and good you use it on this scope which i also have exactly two of them.
Alan Brunelle:
Tareq Abdulla:
Joe Linington:
Alan
Hi Alan,
I buy from Aliex..... instead of Amazon, even eBay is better than Amazon in prices but AE smashed both for prices, i saw a lot of SVBony and other brands products at low prices, i even can buy 50mm guide scope cheaper or same price as ZWO 30mm, so i have enough options to choose, but i have to choose wisely for my 60mm doublets and FRA400 and 90mm triplets and maybe my 6" Newt too, i have QHY mini guide and QHY5LM camera which is an amazing combo, but i do have say 3 ZWO planetary cameras so i don't to buy another camersa only for guiding such as mini versions, i think two guide scopes will be enough.
Later i will think about OAG for my 10" and 8" scopes, there is one OAG very nice i think about to buy from my 10" RC, but i won't keep swapping it for 8" too, so i will buy another OAG for my 8" Newt, but i have to think what i will use, a mono camera or OSC so i can decide which OAG, and which focuser.
At the price i have to think about if i better buy one guide scope or 3 by this price really.
Alan Brunelle:
Tareq Abdulla:
Joe Linington:
Alan
My QHY Mini Guide Scope has same mechanism, front focusing ring and lock, it served me well although in many nights guiding went crazy, or maybe it is something else as i get elongated or coma stars by edges from 3 minutes up to 10 minutes, but i know guiding is good enough because center stars are round and the nebula is there sharp, so it is another issue, but lately last year my guiding didn't work at all and i was using SW Wifi adapter instead of EQMOD, and that killed the guiding.
Tareq Abdulla:
Alan Brunelle:
Tareq Abdulla:
Joe Linington:
Alan
Hi Alan,
Yes, there are many options!  And then throw in the mix with the dual sensor camera that ZWO just came out with, to likely be followed by others, and guiding may be changing before our very eyes.  (though multisensor cameras have been used in the past.)  I have not been attracted to OAG, but I should not be with my relatively fast wide scopes.  Can't really use it with my RASA, but I should have no issues finding stars with my F4 Newtonian.  But my small 60mm travel scope guides essentially perfectly with the 30mm guide scope.  Funny, but I bought the WO ZS61II for a guidescope on my 12 inch Newton.  But always thought it to be a travel scope someday.
Considering a Guide Scope - Never used one
I am very new to astronomy and astrophotography. For just over a year, I have been trying my hand at this astrophotography "hobby". Getting sucked deeper and deeper into this ever-growing desire to get better and it is rapidly developing in...
Considering a Guide Scope - Never used one — discusses guide scope selection and usage for astrophotography.
Apr 16, 2025
DIY guiding system
I am planning to add guiding system to my current setup, for now i am very new to this genre so I don't want to straight away invest into guidecam and guide scope, instead the idea is to learn by making guide system from existing gears (DIY) or g...
Discusses guide scope options, relevant to author's guiding system planning.
Jun 18, 2021
