first time shooting and editing a globularI and was hoping to get some feedback on it. A few things that catch my eye was it might be a bit sort and it seems to bee lacking color. Not sure if the softness im seeing is due to seeing (it wasnt that great), collimation slightly off, focus slightly off, or any combination of those! I use NINA’s autofocus routine and get a pretty decent u shaped curve.
Withregards to the color, not sure on that. Im pretty new pixinsight user, third image ive edited with it, maybe more curves transformation with saturation is needed?
I may have over done the BlurXterminator use. I left the core a little hotter as i think i like it that way.
this is only about 17 minutes of data so maybe a full hour would produce more color?
equipment, data collection, and processing notes:
lights:350@3s
darks/flats/dark flats
b4 skies; backyard
c9.25 with celestron reducer
uv/ir cut filter
celestron oag
zwo asi 174mm guide cam
zwo asi 294mc pro
EQ6r Pro
NINA,PHD2
PROCESSING NOTES
used pixinsight for image calibration, integration, and processing
WBPP
Dynamic Crop
Dynamic Bachground Extraction
SPCC
BlurXterminator
NoiseXterminator
Histogram Transformation
HDRTransformation script
Curves Transformation (contrast and saturation)
final color balance in PS
Adam Blocks tutorials
Any comments/suggestions would be appreciated!
thanks
M13
lights:350@3s
b4 skies; backyard
uv/ir cut filter
celestron oag
zwo asi 294mc pro
EQ6r Pro
NINA,PHD2
PROCESSING NOTES
WBPP
Dynamic Crop
SPCC
BlurXterminator
NoiseXterminator
thanks
M13
