Need help with QHY268M and Narrowband Flat Field Calibration
16 replies1.1k views
jarod avatar
I purchased a QHY268M camera, QHYCFW3 filter wheel, and a set of 36mm Antlia V-Pro and Antlia 3nm SHO filters.
It's been nonstop frustration trying to achieve flat field calibration with the narrowband filters, the broadband flats look perfect.  I've never been able to get flat field calibration to work with the narrowband filters and the QHY268M. It always results in uneven illumination.
After months of troubleshooting, along with help from the reseller and Antlia we've narrowed it down to the QHY268M. This is a list of potential causes that was provided.
  • Angle characteristics of the CMOS‘s microlens structure.
  • The spectrum difference between the Flat panel and the skylight flat field.
  • Small installation angle error of narrowband filters, CMOS microlens error.
  • The focal ratio of the telescope, which causes the incident light to be angularly shifted.
I get the same uneven flat field calibration problems regardless of which of my Newts (8" F/4 and 10" F/5), regardless of reducers, the light source, or QHY gain mode or settings. f I switch out the QHY268M for my ASI1600MM, the problem completely goes away. The issue only happens with the QHY268M.
So, my question is, if the QHY268M's design is at fault, what are other QHY268M owners doing to achieve flat field calibration with narrowband filters? Am I supposed to just accept that my QHY268M doesn't work with narrowband flat field calibration?
Here is an example flat frame. Only looks worse if integrated into masters. This is an HA frame but happens to OII and SII too.
Scott Badger avatar
I have the 268M, QHY filter wheel, but Optalong filters and have not had this issue, though I only have Ha for NB. If it's the camera, and the problem disappearing when you swap it out seems to point that way, is it possible that the problem exists with broadband filters too, but is 'buried' under the wider signal response?
Scott
Jeff Reitzel avatar
I have been using a 268m with my refractors and SCT scope for several years. I saw rings a bit like yours on flats initially with my refractors and felt like it was reflections off something in the scope. I flocked flat surfaces around my flatteners and reducers that were facing the camera and it dramatically reduced the issue but it did not go away.  I eventually found there was no plug in the little port for the desiccant tube at the base of the camera resulting in a bad light leak. Once I corrected that I had no other issues and have really enjoyed the camera. Here are pictures of a current Ha master flat and where you can find the light leak. It's the "arch" shaped hole you see in the image and it goes all the way through the base just in front of the sensor glass.  Hopefully it's not a defective camera and this will help.
Jeff
Brian Puhl avatar
Almost looks like it's reflecting light from behind a filter and back at the camera.   That honestly looks like an outline of the sensor.  I'd say Jeff's idea above is a very solid possibility.
For what it's worth, I, as well have never had any issues with narrowband flats, I hardly even needed them until I started picking up dust.
jarod avatar
Thank you for the responses. I had a feeling this camera could work with narrowband flats.
Scott Badger:
Scott
I would imagine the broadband would be more sensitive, but it's possible.
Jeff Reitzel:
Jeff
That's a good thought. The desiccant plug is in place. This issue also shows up on the narrowband LIGHTs, it's not as pronounced, uncalibrated HA and OII require extensive repair in PI , SII is beyond repair. Attempts at narrowband flat field calibration only make the narrowband LIGHTS harder to repair.  Broadband look perfect, literally never seen better. It's been a vexing issue.
I've concluded that light leaks wouldn't be limited to just the narrowband filters. The filter wheel rotates the filters into the same location and broadband pass more of the spectrum, so really ought to be detectable.
I've tried everything accept replacing the camera. I  just needed to know that replacing the camera isn't a futile endeavor. Since others are able to use their QHY268M without such a pronounced issue. I'm hopeful that this is the right direction.
Supportive
Brian Puhl avatar
Curious, could the filter wheel be out of sync?  Have you looked down the tube of your scope, at the sensor and made sure there's not a blockage caused by the filters?
Jeff Reitzel avatar
Well I was hoping for an easy fix for you.  Other possibly dumb questions on my part but just brainstorming a bit. I am not familiar with the Antlia NB 36mm filters so are they threaded filters by chance? Do they have filter masks on them? Are the filters seated well in the filter slots regardless of how you mounted them? What you show looks so much like light reflecting off the back of the filters I'm just trying to guess possible sources of unfiltered light getting to the camera side of the filters. Including using threaded filters and not putting a screw in each of the 3 holes around each filter that goes completely through the filter wheel. Have you tried turning the NB filters over to see if it improves? To me it does not make sense that this issue would only be there for NB if the camera were faulty. Scott may be right that it is masked with a stronger broadband signal.
Best of luck,
Jeff
Helpful Respectful Supportive
Mike Lewis avatar
Pursuant to Jeff's post above, I had the exact same issue from that missing plug that is supposed to fill that hole. Just to clarify, that hole actually isn't for the attaching the desiccant tube, it is for some other unspecified purpose, as the desiccant tube is threaded, which this hole is not.
My little black plug that is supposed to fill this hole was missing on arrival which I did not realize and so I had lots of issues from this light leak, and interestingly, it REALLY showed up dramatically for my Hα filter compared to my other filters. This little hole that Jeff shows above does not even exist in the design of the OSC version of the camera, and no mention in any documentation from QHY about it. Mine is taped over now and all is well with all my frames (NB flats included…)
ML
Scott Badger avatar
I believe that hole is to allow blowing air across the glass window in front of the sensor if dew forms on it and/or fill the chamber with argon to help prevent dew. See this thread:
https://www.cloudynights.com/topic/859159-calling-all-qhy268m-users-light-leak/
Scott
Mike Lewis avatar
Scott Badger:
Scott
Yes, that is the thread I started when I had the issue. The theory about the hole being used for dew reduction or argon filling is interesting, but I never found any official documentation verifying that fact. In any case, pursuant to this thread, this hole, if unplugged, is able to cause artifacts that resemble what the OP is dealing with.
ML
Well Written Concise
Lynn K avatar
Don't use Bias subtraction on your Flat frames. Not sure why , but it screws up the QHY268 flats. Also, flats can be clipped to the white, resulting in total saturated areas.
Make sure your black point pedestal is set high enough. I use MaxinDL, other programe may set this in other ways. I just had large white arches in my flats. I set the pedestal higher and is solved the problem. The black will be darker with narrowband,  and that be more of a problem, not sure though.
Lynn K.
Dan H. M. avatar
Lynn K:
Lynn K.
I’ve had the exact opposite experience with the 268M - NOT using bias subtraction causes problems with flats. Although I technically do “flat darks” and match the length of my flats to the bias.
Lynn K avatar
Hi, Eteocles, That may be the difference. I don't use use flat-darks.  I'm an older CCD imager and haven't gotten around to changing habits to do that.
Not sure what you mean by matching Bias to Flat frame exposures. Bias is exposed as close to "0" as possible. Did you mean matching your Flat Darks to match your Flat frame exposure times?
I have read/understand that Flat-Darks are recommended with CMOS. Inever used them with Sony CCD. Only used Bias.
Lynn Krizan
jarod avatar
Sorry for the delay in responding to these posts. I've been slammed with responsibilities at work and at home. Here on the East Coast it's been cloudy for weeks. Supposed to clear up tomorrow night here in North Carolina. We go through so much planning and waiting for the right conditions, only to have it wasted due to hardware issues that seem to be beyond our control.
I'm hoping QHY will have a solution to this issue. Otherwise, I'll just part ways with the camera, stick with ZWO in the future, and try to be more careful going forward.
Brian P
l've watched them rotate into place. I even removed my OAG from the equation. No obstructions in the light path. Everything lines up properly.
Jeff Reitzel:
Best of luck,
Jeff
The 36mm filters aren't threaded, they are held in place by a couple of set screws with little cardboard washers. The 36mm filter wheel doesn't have any threads where the filters go. I've tried flipping the filters over, didn't seem to make a difference.
I do agree that the uneven illumination is being masked to some degree by the broadband signal. Now that I know what I'm looking at, I do see evidence of the uneven illumination. This QHY268M produces great results with LRGB, but broadband calibration is required! No way this camera can be used without flats as other have suggested. I suspect this is connected to the microlensing errors, which causes uneven illumination across the sensor.
Lynn K:
Lynn K.
I noticed the BIAS frames from my QHY268M looked strange compared to my ASI1600. They looked more white than black, if that makes any sense? I was suspicious of them at first and stopped using BIAS frames for a while. I investigated everything I could think of, even isolated the power source for the camera, thinking it was picking up interference, but it wasn't. After trying out a few different processing methods I started using BIAS frames again. I can say it's not hurting anything, This camera has so little dark current that they are almost optional.
Lynn K:
Lynn K.
I think that's the best approach, but for simplicity I've increased the exposure time for my BIAS frames. I used to go as low as 0.0001, but now 0.1 seems fine. It's hard to get Luminance flats above 1 second, normally 0.6 or so. Also seemed to make my BIAS frames look more normal to me, though can't say if it's better.
I tried narrowband SkyFlats again, just to experiment, tried at different brightness levels, different angles, and with and without a light diffusor. The only noticeable difference was if I set the gain to 0. If I had to quantify it, might be ~10% improvement. The SkyFlats basically look the same as the ones made from my Light Board.
Scott Badger avatar
A couple things.....
Flats are never optional. Darks, maybe with some cameras like the 268M, but that hasn't been my experience, and flat darks can replace bias. Flats take care of vignetting, donuts etc. Without them you could probably deal with the vignetting with a tool like DBE, but the dust donuts are going to require clone stamping, and we all know that's a road to perdition..... : )
I believe that when you autostretch a bias frame, because of the way autostretch works, the range of dark gray to nearly white depends on how much of a 'pattern' and noise there is in the signal. Less pattern/noise, more white. Better sensor?
I've only heard that you should set the bias exposure as low as possible. In NINA I set it to 0, which results in an exposure much less than 0.1s, though I don't have a sub handy to say what it is exactly.
Why are you trying to get flats above 1s, or targeted to any particular exposure time? Exposure time is immaterial, it's where the peak of the histogram falls (about in the middle) that matters.
Flat darks vs bias. Lots of conflicting advice out there, so I can't comment conclusively, but I raised the question myself a while ago and the advice I got was that for the 268M, flat darks wouldn't give me much of an advantage over bias, so I stuck with bias frames since they're so much easier. Here's the thread: https://www.cloudynights.com/topic/833261-dark-flats/
Gain for all calibration frames should match the lights.
How are you calibrating your flats? I only use only a master bias and I don't calibrate darks.
Scott
jarod avatar
Scott Badger:
Scott
Hi Scott, I agree on the use of Flats. Dark Flats or Bias could be considered optional with this camera.
Your point about the auto-stretch makes a lot of sense. Since there isn't as much noise it's going to stretch it further which would explain the whiteish color.
By definition, BIAS frames are supposed to be as short as possible. It would be more accurate to say I'm in the middle between BIAS and Dark Flats by using an exposure time of 0.1. I can't say it's actually better, but it works well for me.
Good question about why my luminance has a longer exposure for Flats. Previously I worked with Flat exposures as low as 0.1 - 0.2 seconds. Flats will still work with really short exposures, but by lengthening the exposure just a little, it seemed to capture a fuller characterization of the imaging train. I should mention, I use NINA's Flat Wizard with the default settings.
Using different gain settings to correct calibration issues is last resort, technically I don't think gain should matter for Flats, assuming the same gain was used for the BIAS, but using different settings adds unnecessary complexity in my opinion.
This is a diagram on how I calibrate Flats. I only use BIAS frames for Flat calibration. Same as you.
Scott Badger avatar
I also use NINA's flat wizard at defaults. For expediency, I set the light panel as high as I can get away with for the lum flats, then use the multi mode to take all LRGB. The lums are the shortest exposure. Since I change the gain and camera mode for Ha (just to be safe), I'll then set the panel to its highest setting since they take a while no matter what. Anyhow, other than a few tweaks you're doing, not much difference between us….honestly, I was fishing for something glaring to possibly explain what you're experiencing. I never assume anything in this hobby, but it sure looks like a physical issue, something askew, or a light leak, but how that would be limited to the NB filters is baffling….
Scott
Flats undercorrecting in LRGB
Been puzzling for years over why my flats taken with my ASI533MM-Pro / LRGB filters do not completely correct vignetting pattern. I've had the same problem using other cameras and other telescopes; the only constant is the filters, and regardless...
Similar flat calibration issues with monochrome camera and filters.
Dec 11, 2024
QHY268M gains & modes
Hi, I just got my 268M with CFW3 and 36mm Baader filters. So, what gain do you use? According to the QHY website, you should start with mode #0 and gain 26, which I will do, if the clouds sometimes vanish… What is your experience? Anybody using...
Addresses QHY268M setup with same filter wheel and filters as poster's equipment.
Nov 19, 2021
Narrowband filters for fast optics
RASA telescopes, Hyperstar systems and other fast optics is growing quickly in popularity among astro photographers. However popular, these systems requires costly, special narrowband filters with shifted band-pass, and finding good such filters is n...
Discusses narrowband filter implementation and calibration challenges.
Jun 18, 2021
What reasons could affect Flat Frame performance?
Dear Friends, I require assistance with flat frame acquisition. It looks like my flat frames overcorrect the images and specifically in the green channel. I dont understand what the problem is! I had this issue before but usually the problem was ligh...
Discusses flat frame performance problems affecting image correction.
Feb 1, 2025
Problems with Flat Frames and L-Enhance Filter
Hi all, maybe someone can help me with my problem: The flat correction with the optlong L-Enhance filter doesn't work right and creates a colored vignette in the final image. For example, here is an image (taken with a Skywatcher 150PDS newtonian...
Flat field calibration problems with specialized imaging equipment.
Aug 5, 2021
