Advice on Coma Corrector and reducer
8 replies662 views
Christian Bennich avatar
Hey
I have a Skywatcher 200DPS f/5 8” newtonian and are looking to add a Coma corrector to my setup.
I have the default focuser that came with the Telescope and currently imaging with an EOS 50D - which will soon be replaced with an ASI2600.
Any suggestions on which CC to invest in?
Is it worth it to use a combined CC/Reducer?
Tim Ray avatar
I have had good luck with my Baader Planetarium CC. Lots of nice images on AB with the Quattro CC from Skywatcher…
CS - Tim
Oscar H. avatar
According to a lot of people; the absolute best you can get is the Starizona Nexus. You can buy ithere
I know people will say "the best is the TeleVue Paracorr" but I think otherwise, since there are much moresatisfiedpeople with the Nexus.
Another good option if you're a little low on money is the "Badder MPCC"
And yet another CC from Sharpstar which has a .95x reducing feature and less spherical aberration than the Baader CC (so says the Astrobin community if I remember right).
You can purchase it here.
All these will work best with up to an APS-C format.
Of course, another option is the cheap GSO CC, but I wouldn't buy that unless I will use eyepieces also.
Jamie Macdougall avatar
Also interested in this exact question, though I don’t want any reduction in focal length. so that would point me toward the Baader MPCC.
However, I’m currently using the standard skywatcher coma corrector/reducer which seems to do the job fine, and is practically the same cost. I’m not sure it’s worth buying the MPCC just to get rid of the reduction - is there any improvement in image quality?
Mike Dobres avatar
I have been using Skywatcher F5 coma corrector on my Skywatcher 130 PDS and my 14"  GOTO Dobson Newtonian tubes for several years (it came with the the Dobson when I bought it used .
http://skywatcher.com/product/f5-coma-corrector-2/
FYI - spacing from the coma corrector to camera lens is fairly critical.. See this discussion:
https://www.astrobin.com/forum/c/astrophotography/equipment/coma-corrector-backfocus/
Mke
I chose to go with the TS-Optics GPU CC and look forward to testing it.
Kevin Dixon avatar
I highly recommend the Starizona Nexus 0.75x focal reducer/coma corrector.  I have gotten excellent results with the Nexus and my Skywatcher 8-inch Newtonian.
Clear skies,
Kevin
Brian Puhl avatar
I started with a Paracorr.  Don't get me wrong, I absolutely love it…   But it's not made for my F/4 scope.  The focal plane is a bit different and I have to put a spacer on the coma corrector in the focus tube to achieve focus.  This also has been causing some pinched optics that are tough to alleviate.  There's no way to screw them in like on a refractor. Now I only recommend the paracorr if you have an ONTC with a moveable primary.
I picked up a starizona nexus awhile back and I can't say enough great things about it.  For my F/4 scope, it brings me down to F/3 allowing me to suck in an incredible amount of light in a short amount of time.   Downside is you'll need fast filters for it.   Also, the vignette on APS-C is pretty strong but still easily correctable.
Both of these correctors are highly regarded as the best, and I would definitely agree.  The paracorr just isn't as flexible in my setup.   It might work on your F/5 scope, but it will slow it down a tad.  Having both also makes for a rather flexible system, even though I have issues with the paracorr.    (you can see the problem in my recent images if you look at the stars).
Feel free to browse my recent gallery tho, lots of paracorr and nexus stuff in the past month or two.
Dale Penkala avatar
My personal experience is the Sky Watcher Coma Corrector is excellent. You can see many examples on my profile here: https://www.astrobin.com/users/DalePenkala/
Prior to that I used my paracorr but as its been mentioned above it pushes the focal point out much further then I would prefer not to mention it does add 11% magnification to your fl.
The Starzona unit many have great things to say about it and do not doubt it one bit. I just have no experience with it and honestly I don’t want to deal with vineting anymore then what I am now so I just stay away from it and I prefer to keep my native fl of my 12” f5. Again many use it and have great results with it.
Dale
FSQ85 in 2024 or ???
Hi everyone, I'm currently considering purchasing a new optic for astrophotography. At the moment, I have a Redcat 91 here, but unfortunately, it has a noticeable defect and will be returned to the dealer. Before this, I had an FRA300, but it sho...
Not relevant — different telescope type (FSQ85 vs Newtonian)
Dec 28, 2024
Starizona SCT Corrector IV - 0.63X Reducer / Coma Corrector (Backspace requierments)?
SO I have an older C8 and I was encouraged to invest in the Starizonia .63 reducer. Info I found was to establish a back space of 90.3 mm "but at 90.3", the telescope does not focaus clearly. The ASIair can't establish the scopes focal ...
Relevant — discusses reducer/coma corrector backspace requirements for imaging
Dec 22, 2024
Crayford focuser or rack and pinion?
Hi guys! I’m looking for a good reliable focuser to upgrade my SW150explorer. Ideally I want it to have 2 things, rack and pinion, and ball bearings. However i cant seem to find one that has both. Most of them are just regular crayford (no rack an pi...
Relevant — addresses focuser upgrades for Newtonian telescopes
Nov 11, 2024
Back Focus Frustration
I am trying to stitch over my ASI533MC Pro with ASI Filter Drawer and the required 16.5mm spacer for that party of the image train to reach a back focus of 55mm. I know that is solid because I have used it for years on my refractors. I am finally try...
Relevant — discusses back focus and imaging train spacing issues
Mar 24, 2025
