Which equipment (camera) to record your scope during the whole night ?
9 replies779 views
Aygen avatar
I am looking for a camera to record my scope while shooting the whole night. Currently, to monitor it remotely, I have a reolink - but this latter isn't really fit to have high quality recording - offering only black and white footage.
Does anyone has something to recommend ?
Thanks,
Aygen
jewzaam avatar
Assuming you're asking for a home based monitoring solution, not something that is mobile, I'd say look at the Wyze Outdoor camera.  I got one with a solar panel and it's setup in the corner of my yard on the fence and has a view of pretty much everything.  I'll have to see how it does out in the weather.  Thinking about putting a rain shield over it, some thin plastic such as from a 2L soda bottle.
Rob Johnson avatar
I currently use an old DMK camera only VGA resolution b&w but works well, but you might consider the Raspberry Pi camera which is colour and with a RPi circuit board has Wi-Fi and powered by USB a fairly cheap option.
https://www.raspberrypi.com/documentation/accessories/camera.html
Aygen avatar
Thank you ! Will have a look at it.
Nick Grundy avatar
I assume you want to get a time lapse or something of the scope over the course of the night? Or you are looking for something to watch your scope realtime?
I got one of these so I could just watch realtime https://www.amazon.com/gp/product/B088QWZ1P2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1It's usb2 connection so I just plug it in and view it using the native windows camera app.
If you want something recorded, you could probably use the same method for the all-sky camera without the fisheye lens?
If you don't care about the cost, maybe a standard ring camera would work? (and set it only to record the motion events like slewing, etc)
George Hatfield avatar
We use Blink cameras to monitor our home, and they might work for your application.  They are inexpensive and can be turned on and off when you want to check something (via wifi).  Like any other IR camera for dark areas, they are BW.  They are battery-powered (last months) and easy to install.  If you are using them for security, they can turn on with motion and alert you via your phone.   Amazon has sales prices periodically which can provide a 50% discount.
George Hatfield
Well written Helpful Respectful
Aygen avatar
Thanks all ! I should have been more accurate in my request.
As  correctly suggested by @Nick Grundy, what I need is a colored camera which will allow me to do time lapse (record the movement of the scope, respectively the night sky). Therefore, I am ruling out traditional security camera.
Meanwhile, I was suggested to have a look at “spencer camera”. Will see.
Nick Grundy avatar
I think this might a be a good option https://patriotastro.com/all-sky-archive/
I went through the youtube of this all-sky build. It was fairly simple and most of all, easy to access the time lapse video at the end of the night. (i want the lazy version)
I've run this before with an ASI585mc + fisheye lens and the capture looked good. In your case, you could just place it so the scope+mount are in the foreground?
Aygen avatar
Thank you Nick, might be indeed an excellent solution. I could built one quite "easily". Very good idea.
DavesView avatar
I use Reolink 5MP and 8MP and they work fine for my purposes. With lights out, you won't get a color image from any camera, just guessing here. The benefits I find with Reolink and monitoring my scopes while I sleep: PTZ with follow (I have two that have a programmed PTZ route), turn on a camera based light when a person is detected with auto switch to color as an option, turn on a camera based siren when a person is detected, camera based speaker and microphone. Also, one PTZ camera that monitors my scopes is 5X optical zoom, while another is a dual PTZ camera with one of them being zoom and the other being wide field.
Anyone using an IMX461? Thoughts please
Hi folks, I have a CDK14 with an ageing FLI PL 16803. I have an FLI CFW 5-7 filter wheel with 50mm square chroma filters. I'm thinking about getting an IMX461 as I like the 16803 sensor size. Not keen to risk disappointment with a GSENSE 4040 wit...
Discusses camera sensor options for astronomical imaging applications.
Mar 5, 2025
Wide ange camera for monitoring scope position and sky/cloud
Dear all, As I am now travelling much more, I would like to operate remotely my scope on my rooftop terrasse over several days without being home. On the paper, it is not a big deal because the scope is permanently on the terrasse anyway and I regula...
Directly addresses remote scope monitoring camera needs for nighttime use.
Apr 3, 2025
Can I execute multiple plans in a single night?
I have looked for information on the topic, but I have found anything definitive. I would like to be able to execute a few Asiair "plans" in a night; to be specific, something like that: plan 1: start at 8:00pm; take 40 frames of target A; ...
Relevant for planning multiple imaging sessions during single night observations.
Oct 13, 2024
ASI 2600 MM - recommended gain and exposure time for NB
Hi guys. Recently I upgraded my remote rig with an ASI 2600MM Duo, mounted on a reduced FRA400 (280mm@f3.9). I found the sweet spot for broadband targets with 300-360s exposures at gain 100, but I can't find the right exposure time for NB (Antlia...
Discusses camera settings for nighttime astronomical imaging with quality considerations.
Mar 27, 2025
