UV/IR cut filter for use with Quark Chromosphere. "Where" does it go?
6 replies434 views
Jamie Macdougall avatar
Hi all,
I've seen countless posts online about "which" UV/IR cut filter to use with the Quark Chromosphere, but I'm struggling to understand "where" it should go.
I have an Esprit 100, Quark Chromosphere and ASI174MM. I've used the Quark and 174 combo successfully with an old 80mm scope, but never tried with the Esprit 100 - I know I need a UV/IR cut filter first. Everywhere online seems to point toward using the cut filter in front of the diagonal - but I'm not using a diagonal.
Am I right in thinking I can just purchase a 1.25" mounted filter and screw it to the front of the Quark (the silver threaded adaptor)?
I'm thinking this Baader filter will do the job nicely. I can get hold of it quite easily and I like Baader:
https://www.baader-planetarium.com/en/baader-uvir-cut--l-filter-–-cmos-optimized.html
Thanks for your thoughts.
Luka Poropat avatar
Yeah the UVIR should always go just after the primary objective, if using a diagonal before a diagonal, but also keep in mind once above 80mm I would consider a front mount energy rejection filter, you can never be too safe with a "normal" scope + quark. If you are asking if it can be mounted there on the quark im pretty sure yeah..
Luka Poropat:
Thanks Luka. My research so far shows that although a front mounted ERF is a great way to go, it's not strictly necessary below 150mm. That's directly from Daystar within the written documentation that comes with the Quark, but other sources online confirm this too. It's also *very* expensive
Yes, that is exactly where I have mounted it on mine, with a 100mm refractor.
Yes, that is exactly I have mounted it on mine, with a 100mm refractor.
Excellent, thank you!
Nick Grundy avatar
I had a spot for a 2" UV/IR at the front of my diagonal (keeping the mirror cooler as well)
Eddie Bagwell avatar
The UV/IR filter can go anywhere in front of the Quark and if using a diagonal, it should be used just before it. A front ERF is not need for your size telescope. You are correct about the threads on the front of the Quark, a 1.25" filter can be placed there.
CS, Eddie
Dealing with IR
I find myself in a rather odd position, that is asking for advice rather then giving some, but here it goes… I have a Nikon D5100 with the IR cut-off filter removed and replaced with a clear filter, so IR isn't blocked anymore. So far I'...
Discusses UV/IR cut filter placement and usage with specialized equipment.
Oct 14, 2021
Any need for an IR/UV cut filter with a ZWO ASI 2600MM-Pro mono camera, which doesn't have a IR/UV cut window?
I have ordered a ZWO ASI 2600MM-pro mono camera (for luminance mainly initially anyway) which doesn't have an IR/UV cut off window. Do I need an IR/UV cut filter for it as currently I do not have any CA using my ZWO ASI 2600MC-Pro colour camera (...
Directly addresses UV/IR cut filter usage and placement questions.
May 26, 2021
