Should i use a Barlow lens instead of drizzling in lack of focus length and aperture?
2 replies214 views
Haakon Rasmussen avatar
Due to the immense cost of buying a new telescope with larger aperture and focal length,  i am using the Bayer/transX drizzling  technique instead. Question is: Would it be better to use a coma corrector with 1.5 magnification (from APM)? The seeing in the south west part of Germany is mostly bad i understand. I am using  a color camera with the IMX571 sensor (pixel size 3,76) with a telescope with 800mm focal length ratio F4.
Or is there nothing to gain, when the aperture stays the same? Or could it be that i loose  details using the drizzle technique?
I hope someone could shed some light on these thoughts.
CS Haakon
Haakon Rasmussen:
CS Haakon
You would gain potential resolution only if you're under-sampling the PSF. If, as you say, the seeing is mostly crap where you are then there is nothing to gain by either drizzling (not CFA drizzle) or increasing the focal length (which would also make everything dimmer for the same integration times). Even CFA drizzle ( I assume you're referring to this) comes at a cost of signal loss so you need to thread carefully there too. Otherwise,if you can afford the extra integration times, you'd be better served with a longer focal length.
Thank you, Andrea!
I will perhaps try the APM 1.5 Barlow Coma Corrector lens.
CS Haakon
Well written Respectful
Fast Scope vs Large Aperture
I tried to get some feedback on another forum but it was crickets so I am going to try here where there is good conversation. So I have literally spent hours reading about this the last few days. I am not nearly as smart as many of the people in this...
Discusses aperture and focal length trade-offs relevant to telescope setup optimization.
Feb 20, 2025
First telescope with the ASI2600MC Pro
Hi! I am relatively new in the DSO astrophotography and I could use some help in determining what telescope I should get. I have. ASI2600MC Pro AM5N I was hoping to keep the cost below $2500 but if there is a clear winner like the Esprit 100, I will ...
Uses ASI color camera for DSO astrophotography, similar equipment and application context.
Oct 7, 2024
Drizzle/Binning/Resampling
Fellow Astrophotographers, i am having a day off and thanks to the bad weather no new data to process, so I decided to make a comparison of (the same) differently sampled luminance data of my latest project. what do we look at? https://www.astrobin.c...
Directly addresses drizzling technique author is currently using for image processing.
Dec 22, 2024
Choice a new camera for a dual rig setup.
Hi, I am deciding for which camera to purchase in conjunction with my William Optics GT81 WIFD reduced to 0.8x (382mm f.l.). Whereas, in parallel I have a WO FL120 @0.8x with a Poseidon M Pro - IMX571 Mono (1.24"/px and FOV 2.16°x1.44°) with whi...
Discusses camera selection with specific focal length considerations for astrophotography setup.
Dec 7, 2024
