allen456 avatar
Bear with me, it's complicated. I was imaging with a C11, .63X reducer flattener, NBZ filter and an ASI183MC Pro camera. It was on a CQ-350 mount, with ASIAIR+ and EAF focuser. Guiding was with the Orion 80mm short tube (fl 400mm) with the ASI178MC camera. I was imaging M82 and shot 165 frames at 120secs, 111gain (unity), Bin1, -10C. I did polar align and ran the autofocus routine before starting. My guiding graph was excellent with Total RMS never reaching higher that .9 arc secs and sometimes as low as .3 arc secs. One thing different was that the PHD calibration wanted to use a star at the very edge of the screen. I selected a single star, so I wasn't using the multi-star calibration. I thought of going back to it but my guiding seemed excellent so I didn't mess with it. My images looked good but a couple of time I noticed that my images would move, slowly but steadily, in one direction for awhile (as if tracking had stopped). Then suddenly it would go back. The guiding graph would still look good and the images would look good. I thought this might cause me to lose some frames but it wasn't until I downloaded and Blinked the images that I realized that this had happened more than I thought (mostly it was horizontal but some events were vertical).  When I tried to calibrate and stack the images (in Pixinsight) most of them failed to register.
Any ideas as to what could have caused the movement to occur in the first place? I am totally at loss for this, according to guiding graph it never should have happened.
Walter Leonhard Schramböck avatar
I had exactly the same issue when i tried to do DSO with my 0,45x reduced Mak. On an other night I wanted to do planetary imaging and noticed that my guidescope adjustment was way off, it pointed somewhere else. So I assume that this caused the drift. But maybe not, I don't know.
James (Jim) Poulette avatar
I've only been using the ASIAIR+ for a few months, but the first place I go is the guide log. I've found that often if the app is doing a re-focus, or dither routine, it sometimes will keep acquiring images. Out of every 100 exposures I usually have to take several out because of, what look to me like, re-focus or dither movements. Sometimes the timing correlates with one or the other, but then again sometimes it doesn't.
I will say that overall I'm pleased with the results, but like I said - I always have to "blink out" a bunch of lights. Good luck.
Edit: I've added 5 raw consecutive 60-sec lights (from a 180 frame set) that show what I've experienced. Frame 61 is fine, frames 62, 63, and 64 (3 minutes) it does it's funky thing (re-focus I suspect), then frame 65 is back to fine. No biggee as I just blink them out. Like I said, I'm fairly new to ASIAIR+, so if anyone can confirm please do !
Long Focal Length Imaging
Trying to figure out if I'm going crazy or if I have an equipment issue. I just started trying to image using a C11 and Starizona .63x reducer. I just purchased a used EQ6-R Pro for it to sit on and I get round stars.. but guiding error is around...
Author uses C11 with .63x reducer; post discusses similar setup troubleshooting.
Apr 17, 2025
How can I improve star shapes?
I recently acquired a new telescope and while first light was successful, I am a bit concerned about star shapes in the corners of my image especially as it's not a cheap scope and I am using a small sensor by today's standards. My imaging tr...
Author concerned about image quality; post addresses star shape improvement techniques.
Jan 28, 2025
