Asiair will not save Subs
4 replies236 views
jose ortega avatar
My asiair plus  has been working perfectly for the last six months .. the. Suddenly last night the anomaly began… 1.     The asiair refuses to save images to preview and live options…while the images were being properly rendered on the screen, they were not being saved on the internal memory. The same phenomena occurs when I insert an external usb card.2.     Oddly, the Asiair plus is able to save both video and auto run options3.     The loading is exceedingly slow 3 kb per second using both a 294 Mc pro and a 385 What I have attempted to do … 1.     Have reset and restarted system numerous times, no effect2.     Have removed hardware from system to only attach one camera to the device, no effect3.     Have re installed the ipad software, no effect4.     Have reset system software four times, while claiming successfully installation, no effect. Observations … 1.     The last few days the system reported formatting errors which were solved with the offered solution to format… by pressing. “Format now” option2.     It seems to me the drive is corrupt… Questions: 1.     Is it possible to reload the firmware on a clean drive…2.     Is there a deeper reinstallation to factory conditions not offered by the internal reset option.3.     Is this a hardware issue? I note that all of the other functions of the device Asiar plus work normally, except for a)     Failure to save to preview and live options b)     Slow 2-3 kb loading of images Any assistance will b appreciated…
daywalker avatar
plenty of hard drive space left?
jose ortega avatar
yes, clear
AstroCane83 avatar
Mine has never saved previews. I haven't tried in live.
Christian Proulx avatar
I was in a similar situation, but a little different.
I could manually save my images when viewed on the application desktop (in preview mode). But in Autorun mode and sometimes in Preview mode, when the application loaded the image (loading with no progress bar), I lost the acquisition.
I wasted about 2 hours of my time trying to fix the problem. (In the woods at the National Park in my province)
I'm in nomad mode and when I reinstalled everything at home (80-minute delay) no more problems, really strange…
ZWO ASIAIR Pro Shutting Off - New issue since software upgrade
I am having issues with my ZWO ASIAIR Pro shutting off on me during the EAF process. I have a complete ZWO setup: 6200mm pro camera, 5 slot 2” EFW, 120mm guide camera and the EAF. My mount is skywatcher and is powered separately through a portable ba...
Software bugs causing system failures similar to your reboot problem.
Oct 30, 2021
Why my mini PC randomly crashes??????????
As the subject states: during astro session (taking astro images at night :in-love my mini PC randomly crashes. My setup is fully automated meaning that I set NINA Advance Sequence, I go to bed and when I wake up in the morning I find my scope parked...
ASIAir Plus crashes could relate to storage/performance issues causing slow loading.
Apr 10, 2025
