Data Retention (calibrated lights vs raw + library of calibration frames)?
13 replies816 views
How much data do I retain?
Multiple choice poll 52 votes
42% (22 votes)
54% (28 votes)
4% (2 votes)
Nick Grundy avatar
I'm curious what everyone else out there does in terms of archival and data. For the past year or so I've been keeping everything (lights, cal frames, masters, etc) As expected, this is getting much larger, so I've recently started dumping raw calibration frames and only retaining the masters. This has helped, but I'd love to hear what everyone else does
Do you retain everything? How?
Do you retain all raw light frames? Or do you save only calibrated light frames?
I'm thinking of only retaining calibrated light frames. Is there a well understood bit rate to do this at? 16, 32, 64? The idea of losing data haunts me.
I appreciate hearing any of your insights on this
Ruediger avatar
Hi Nick,
I keep all the raw data, plus the calibrated master. All intermediate data, which can be re-generated (calibrated, registered) gets purged after closure of the project. Not because of the data amount, but the time the backup needs to be replicated off-site.
Rüdiger
Well written Concise
Paolo avatar
I keep:
  • raw light frames
  • calibrated masters (bias, dark, flat)
Nick Grundy avatar
what's the average data size we are all holding? I'm sitting on about 2TB. Wondering how you all manage that? replicate offsite? NAS?
Ruediger avatar
Nick Grundy:
Hi Nick,
my AP data is approx. 1.8 TB, which is actually not a big deal compared to the rest. I am keeping the data replicated two times locally (on- and offline) on real NAS Servers RAID6/ZFS Z2 and replicate one set off premise to another NAS via permanent IPSec tunnel.
Rüdiger
Paolo avatar
Thanks to the weather, I don't have to spend much for HDDs smile
I currently have a RAID 1 of 2 4tb HDDs, and I have plenty of space available.
I also backup a copy online (B2 now, something else past the 2tb).
Doug Summers avatar
Keeping raw light frames (FITS) and calibration masters (dark, flat, flatdark), helps minimize storage but still allows for reprocessing (if desired).   Otherwise, retaining xisf files begins to really suck up disk, especially as the number of images kept in your archive increases.
Brian Puhl avatar
I'm glad someone posted this poll….  I'm starting to eat through hard drives rather fast… lol    I've been debating chucking the raw files and keeping only the Pixinsight directory.
Nick Grundy avatar
I've been thinking about only keeping calibrated light frames. (so I can be more in the habit of taking flats nightly, then dumping them regularly)
I've been trying to decide if I can save my calibrated light frames 16-bit integer FITS without losing any data. I've tested stacking from a calibrated set of 32 bit float FITS vs a stack of 16-big integer FITS, and I can't seem to tell the difference. Maybe one of you all knows the more technical explanation or answer?
I dropped a couple subs + the stacked HA images to see if you all can tell the difference.
I most definitely want to keep light frames, but i think restacking them on later dates is so much easier when I don't have to remember which flats/dark flats and such go with each date. (I tend to collect more data and restack from some older data or optics to see what comes of it)
I'd love to hear how you all handle this
https://drive.google.com/drive/u/0/folders/1TOpSVKz-kXbfmy1wKNXK4wzPpQ8Tx0j1
Wei-Hao Wang avatar
Raw files are the direct output of your hard works at night.  Never delete them.  Hard drives are dirt cheap compared to your other astro equipments.  Buy several large hard drives to store the raw files and make backups. (Get a fast SSD for processing.  Don't use hard drives for this.)
I keep all the raw files and master calibration frames (since they can be reused again and again). I keep stacked linear images.  I also keep all intermediate processing steps toward the final, so I can go back to whatever step any time if I am not satisfied with the final. I don't keep calibrated single subs because they can be generated rather easily from raw and master calibration files when necessary (truth is this is rarely necessary), and also because calibrated subs take more space than a single stacked final.
Oscar H. avatar
At the moment, I don't delete any of my subs or calibration frames. I save all of it. But later I will only keep the final image because the rest will take up too much space.
Nick Grundy avatar
For the last 6 months I generated about 1.8TB worth of data (light, cal, frames mostly). I upgraded more recently to the asi6200 which doubled the size of subs, and started doing more planetary/lunar. I didn't get crazy on the math yet, but I'm estimating 3-4TB of new data over the next 6-7 months. That's not a small number anymore. No one else is having this issue yet?
If we have the calibrated light frames saved already, how come we wouldn't delete the flats? Is there something that happens in calibration that will differ later? I've noticed that saving the calibrated frames in 16-bit integer files from Astro Pixel is the same size as the raw subs. (so no major benefit in storage) Technically is there some data lost if I save them in 16-bit integer? It's the same bit rate as the original sub if I understand it correctly. Does anyone know for sure?
Doug Summers avatar
If you're saving the calibrated light frames, then there would be no need to save the flats, but the question is why do that as opposed to saving the master flat, master dark, and just the raw fits files?   The storage requirements would be much reduced (at the cost of needing to reprocess if/when necessary).
Well written Insightful Respectful Concise Engaging
Nick Grundy avatar
Doug Summers:
at least according to what i've seen (based on ASI6200 fits files), the raw sub is around 120mb. A calibrated sub can be saved in various formats (32bit float, 32bit integer, 16bit integer, 8bit integer).
Actually, I just found the answer in APP forum. Apparently, I would lose some data if saving the calibrated frames at 16bit instead of 32bit. So it's clearly easiest to store the raw lights + cal masters I think.
Now I just have to plan for more storage
